Introduction: Cardboard Connections
Cardboard Connections are fun to build inside. These ones are easy to make using rolled up cardboard and balloons. If you want to cover one, just lay over a light sheet.
Step 1: Nodes
The hut structures are made from nodes and cross members.
Nodes are made using balloons:
  • Blow up a balloon to about 15cms in diameter.
  • Tie a knot to stop the air coming out
  • Repeat the same process for the number of nodes required
Step 2: Cross Members
Cross members are made from rolled up cardboard.
To make one:
  • Cut a length of cardboard
  • Roll up the cardboard into a tube
  • Secure with some invisible tape
Step 3: Joins
The cross members are joined together at the nodes made from the Balloons.
  • Use invisible tape to join the cardboard tubes to the balloon nodes. Contact glue could also be used.
Step 4: Construction
Making triangles using the balloons and cardboard tubes will give your structure strength.
  • This is done by joining 3 tubes to make a triangle
  • Legs can be added to the triangle to make a simple table.
Step 5: Versatility
A variety of designs can be made, as long as you use a few triangles in its' construction it should be strong enough. If you then want to make a different design, the tubes can be disassembled and reused.
