Introduction: Cardboard Pendulum Clock
I designed this clock off of a Pendulum Clock. Since Pendulum Clocks are very hard to make, I thought I would challenge myself and try to make a fully functional one. All the supplies I used were found around my house, so It was free and fun to make.
Cardboard
Hot glue
AA battery
Tape
Scissors
Clock Motor
Clock Hands
Step 1: Cutting Out the Frame
I first started by cutting out the frame. I had to measure the perfect size of the hole where I would put the Pendulum. Then I had to figure out where to put the hole where I would put the clock hands.
Step 2: Attaching the Clock Motor
I took an old clock motor from an old clock found it in most people's houses. I fit the clock motor through the hole made in the clock face. I powered the motor with a AA battery.
Step 3: Attaching the Pendulum to the Clock
The first thing I did to attach the Pendulum to the clock was attach a notch a the top of the Pendulum piece. Once I had that, I attached it to a baring inside the clock to move and stay moving.
Step 4: Attaching the Base and the Top
This part of the build was the easiest. I started by getting 4 different-sized pieces and gluing them together. Once I got my base and top of the clock, I attached them. I decided to have my clock sit on the table, so I put rocks into the bottom.
Step 5: Attaching the Clock Hands
I made sure the motor was still in place and working, then I put the clock hands on the motor. I let the clock run for 12 hours to make sure it was reading the time correctly.
Step 6: Making and Attaching the Wall Attachments
Pendulum Clocks can be either hung from a wall or sitting on the ground. I built it both ways as I could hang it on the wall and sit it on the ground or a desk. To make the Wall Attachment, I cut out a piece of cardboard and put some steel blades in the piece of cardboard. I got the steel blades from an old pair of scissors.
Step 7: Final Product
In the end, the clock turned out great and worked correctly. The tape on the clock represents 12,3,6 and 9 on the clock, just like on a real one. The Pendulum took a really long time to get right, but it was worth it in the end.
