Introduction: Cardboard Pineapple Pen Holder
This pen holder is very easy to make.
You need very little things to make this pen holder and you don’t even need glue to make this. If you are creative you can make modifications to this by adding something to this. Follow these simple steps to make this pineapple pen holder. Hope you will like this…..
Step 1: You Will Need:
Cardboard
Pair of scissors
Pencil
Ruler
Crayons
Step 2:
Draw 4 circles of 5 cm radius on the cardboard and cut them out.
Step 3:
Divide each circle equally into 8 sections and mark it with a pencil.
Step 4:
Make cuts of 1 cm length from outside the circle along the pencil lines marked in the previous step. (fig.1 shows the cuts in red color)
Step 5:
Take 3 circles and draw a circle of 2.5 cm in the center of each 3 circles. Cut and remove each of the center circles. (Remove the green color area in fig.1)
Step 6:
Take a cardboard of 15*6 cm and draw a half of a pineapple shape as in fig.2.
Step 7:
Cut it off and use it as a block to draw the other parts.
Step 8:
Using this block draw the shape on the cardboard and cut them off. You can use a decorative border scissor to get scallops at the outer edge of the half pineapple shape. If you don’t have this kind of a scissor you can make small scallops using a normal scissor. Make 8 from this shape.
Step 9:
Make cuts of 1 cm length on the half pineapple shape as in fig.2. (Fig.2 shows the cuts in red color).
Step 10:
Erase all the pencil marks on circles and half pineapple shape.
Color all the shapes cut from the cardboard with crayons using suitable colors.
Step 11:
Connect the circle shape to the bottom of the half pineapple shape through the cuts. Then connect the ring shapes to the half pineapple shape through the other 3 cuts.
Step 12:
Connect the remaining half pineapple shapes to the circle and rings in the same manner.
Step 13:
Adjust all the parts carefully to get the desired.
Step 14:
Now your pen holder is ready to use.
