Introduction: Cardboard Skull
You can make typical Mexican skulls, you can also make hand painted mushrooms
Step 1: STEP 1: Material: Scissors, Glue, Cardboard Paper, a Small Razor, Oil, Plaster, Brushes, and Watercolors, to End of the Steps You May Use Varnish.
Cut the paper carton into small pieces, you need to have a sample skull, it can be unicel skull, wood skull, or some other material as in this case I use synthetic resin skull
Step 2: STEP 2:
Before starting, it is necessary to cover the mold with plasticine, only to cover holes and that the mold has a smooth surface Cover the skull with the oil, immediately cover the skull with the pieces of cardboard paper and the white glue, only place three layers of cardboard paper. Wait 15 minutes for it to dry. After waiting, a small cut is made in the back of the skull, in order to remove the mold.
Step 3: Final Step.
Once the mold has been removed, proceed to close the cut with more cardboard paper until it does not leave a mark on the cut, it is also recommended to cover the whole skull with more cardboard paper, it is placed enough to be a solid piece.
Once the skull is covered with more cardboard paper, it should be allowed to dry for at least 5 hours, after which time it is painted with plaster and allowed to dry for 30 minutes.
The last step is to paint the skull, it can be painted in different ways, but these skulls are typical of mexico, so they are decorated with flowers.
