Introduction: Cardboard Watch Strap
Hello, This will be a tutorial on how to create a luxury watch Strap using the following materials listed below.
The tools/materials needed: Cardboard, scissors, cardboard cutter (or anything that can cut through cardboard), hot glue gun, sandpaper, small round watch clock, different colored (any type) paper,
Step 1:
These are on how to cut the cardboard to make the watch strap (1 inches in the side and 10 inches in length)
Step 2:
Make another watch strap with the same exact measurements
Step 3:
attach the strap to your hand and see where the strap fits you best (if it doesnt fit good for you then, you can make some few adjustments to make it longer or a little wider)
Step 4:
Use the hot glue to glue on the cardboard and after you added hot glue, make sure to add the other cardboard watch strap on top of that (remember: dont burn yourself with the hot glue)
Step 5:
once you added the cardboard strap on top of the other, then it should look like this
Step 6:
once after that, bend the cardboard until it looks like this, in order for to work as a watch strap
Step 7:
stack 2 green papers on top of each other before folding
Step 8:
after folding the paper 2 times, draw like a small rectangle on the edge of paper before cutting
Step 9:
Draw a small small rectangle for the other side before cutting it with scissors
Step 10:
once done the prevouis steps, begin cutting both sides with scissors
Step 11:
it should look like this after cutting
Step 12:
the results should look like this ready to attach for the watch strap so it can look nice
Step 13:
add the green paper to left and right side of watch strap (you can make any design on it which means you can make some any changes you want but you can see here that i made these designs for watch strap
Step 14:
have the sand paper ready to cut. measures for width to cut is 1.5 inches and length should atleast 4 inches long)
Step 15:
it should be a rectangle cut and after that, there should 2 cuts which make rectangles and then stack them on top of each other and cut it in the middle which make sqaure cuts that look like from the image
Step 16:
use the hot glue to glue the sand paper on the cardboard strap on top of the green paper to make a good design on the watch strap. (you also need the metal lock that belts have and you can see that I have one from a belt but you can use any type, as long it can be used as a lock like mine.
