Introduction: Cardboard Pencil Case
Cardboard is everywhere!
USE IT!
this pencil case works great for little kids, you make it they decorate it and use it!!
use simple tools found in the average home.
Step 1: You Will Need...
a sheet of 12cm x 12cm sheet of cardboard with a crease in the center.
5cm x 18cm sheet of cardboard,
pencil,
scisors,
rope,
and a hot glue gun.
Step 2: Measuring.
Measure 9 cm up and mark it, then measure 2.5cm on the bottom. Using a ruler draw a line frome the center line to the outer eges of the first line.
Step 3: Cutting
cut out the first triangle and then use it as a stencil to make anothe, then cut that one out.
Step 4: Gluing
Glue the triangle beetween the large sheets crease.(look to picture for details)
do the same on the other side.
Step 5: Poking Holes
Poke four holes two on each side and tie string to them.
Step 6: You Are Done.
