Introduction: Cardboard to Sled
I'm going to show how to make a sled from cardboard. I know it looks kinda weird but it still works.
1. Large Cardboard Box
2. Large Scissors
3. Tape
4. Ruler
5. Marker
6. 2 Plastic Bags
Step 1: Making the Sides and Top Part
Get your box and cut an edge, you should have 4 big flaps and 8 small flaps. Cut a flap on the side, but don't throw it away, now there should be 3 big flaps. On one side use your ruler to measure 5 inches from the side mark it, draw a line from top to bottom and it should cross were you marked with your ruler, then cut on the line with you scissors and then do the same with the other side. Cut a square on a side but don't cut one side of the square then fold and you have a door. Stand one side up fold the small flaps then the small flaps in the middle and tape them together and do the same on the other side except don't make a door.
Step 2: Making the Bottom Part
Get the flap you cut off then cover a side fully with the plastic bags then tape 'em. Make sure it is flat so it goes fast. You can rip the bags then put it on the cardboard if you want to. The bags will keep the cardboard from getting wet.
Step 3: Puting It Together
Put the top part on the bottom part but not where you put the bags. Tape them together really well because you would not want to fall right in the middle of your fun. On the front at the top tape it then tape the other side of the tape on the wall on the back of the front and the front should be lifted and should be a snow barrier so it can block snow and the front doesn't get in the way. Tape where you taped so it can be strong and finally your finished.
