Introduction: Cardbord Pinball Machene
have fun with your friends playing fully functiol pinball!
cardbord
Hot glue
Skewers
Rubber bands
Step 1: Cut Out Your Base
cutout the exact size that you whant make it look kinda like the photo also start heating up your hot glue gun
Step 2: Cut Out Top Part
however big your base is cut out the top the same sizeit should look like this
Step 3: Start Cutting Out Your Flippers
cut out 4 flipers each so 8 in total use 4. Use 3 for holes the last one has to be one with no holes at all it should look like this but make shure your back has 3 holes it should be about half a inch make 2
Step 4: Glue in Skewers
hot glue in skewers than put in top its as easy as that for this step!
Step 5: Step 1 of Mecanisam
tape down your flippers in position tha t you want than put on 3 cardbord pices all hot glued add the 4th one and it will not have holes make 2 make sure the piece is 3 and a halph inches long and 1 and one third inches for with hot glue all pices together and hot glue the piece onto the skewer as shown in the picture it should be sturdy
Step 6: Add Barier
in this step you need too add a small pice that is a barier and than add a skewer on top The barier should have a opening at the to it should look like the picture
Step 7: Start Makeing Buttons
make 6 of the same size pushers make 3 per side and glue them together and put a skewer on the buttons it should look like the picture and it should have a button kind of thing than you need to put on rubberbands on both sides it should come back
Step 8: Add Another Skewer to the Back of the Fliper
add a skewer to both sides attaced to the fliper add a ruber band to those sides and if it does not come back proprly add a stabliser a small peice to make it come backmy problem just had to just make a barrier and i also fixed it with the rubber bands it should look like the picture
Step 9: Hot Glue on the Top and the Base and Add Ramp for Ball
start of by cutting holes for the flippers in the base than make a cup thing and a hole for the ball to go into it should have a ramp add suppors and back board if needed for it after it should look like the picture
Step 10: Decorate and Obsticals
next you have to paint and make obsticals i dont have a picture but just make obsticals and paint it!!!
