Introduction: Carriage Style Hearse (aka "The Sin Eater")
OMG...WHAT SORT OF NEIGHBORHOOD DID WE MOVE INTO?!?!?!?
At first I was both hurt and embarrassed, but later realized the only way to get back to "anon" was to create a bigger and better display each year. I now claim myself to be the victor because "anon" has stopped renewing my subscription to Guideposts (a faith based magazine) and each year the cemetery compliments increase.
I have added a carriage style hearse to this year's haunt, and designed it with following in mind...
- easy to set up and take down with minimal storage requirements
- inexpensive, using as many recycled materials as possible
- simple construction, using hand tools and a drill, dremel, jigsaw, staple gun
- sturdy enough to withstand wind gusts up to 60 mph
Step 1: Breakout/Breakdown
<$25 - Four Wheels (could've gotten away with only 2, since only one side is visible from the road)
450' Lawn Edging (for rims)
8' Metal Conduit (for axle)
2 "borrowed" Saw Horses (to support body and wheels)
Plastic Ivy (to hide sawhorses)
Oops Paint, Culled Lumber, Screws
Decorative Mirror (to represent a window for corpse viewing - ha, it's reflection is you!)
Stretchy Fabric and Dowels (to resemble drapery)
Sconces (to give the illusion of candles/lighting)
Oops Paint, Culled Lumber, Screws, Hinges, Wire, Cuphooks
Decorative Mirror (for more corpse viewing)
Upholstery Trim (painted gold to hide gaps between the top and the base)
Sconces (to hold reins)
Scrap Foam (for seat and to support sconces)
Stretchy Fabric and Dowels (to resemble drapery, cover seat)
Xmas Pediments (to dress up driver foot area)
Oops Paint, Culled Lumber, Screws, Cuphooks, Decorative Tacks
Step 2: Dimensions
I started with the casket section of the hearse (base/body) and wanted it to be about about 75% of the length of a person/casket, or apx 48" long - which was ideal because culled lumber is generally not cut at lengths greater than 48".
The next challenge was trying to figure out how long to make the (front) section where the driver sits. Google'd images suggest the front of a hearse is about one-half to one-third of the length of the casket base/body section. Since I wanted the casket area to be the focal point, I figured 24" length for the driver was reasonable.
Finally, almost all photos suggest front wheels are shorter than back wheels and that the height of the driver's foot rest is visually the minimum height for the front wheel. Knowing he hearse would be immobile (with sawhorses blended in to support it), I knew the centers of the wheel hubs had to be located within the side support/gusset of the sawhorses. By measuring from the ground to the upper/lower distance of the sawhorse side supports, I was able to estimate the wheel's radius range.
After playing around with the above proportions, the final dimensions worked out to approximately:
Overall Height (ground to top) -68"
Overall Length (front to back) - 66"
Overall Width (side to side) - 28" without wheels, 48" with attached wheels
Excluding decorations, this is further broken out as...
Front Wheel
100" Circumference (with overlap)
6.25" Hub
13" Spoke Length
5 lbs Weight (each)
Back Wheels
38.5" Total Height/Diameter
124" Circumference (with overlap)
8.25" Hub
15" Spoke Length
6 lbs Weight (each)
Sawhorses H: 28.5" x L: 18.5" x W: 33"
Styrofoam Base H: 29.5" x L: 45" x W: 23"
Surrounding Body H: 32.5 x L: 47" x W: 26" (add 4"" to height for decorative pediment)
L-Shaped Molding
Top/street side only H: 3" x L: 48" x W: 3"
Top/back side only H: 3: x L: 28" x W: 3"
Back frame (which is hinged to the Top/back side) H: 32.5" x L: 28" x W: 1"
Front Box H: 17" x L: 19" x W: 24" (add 3" to height for decorative rein holder)
OK...enough of the details - let's see how the "Sin Eater" comes together...
Step 3: Wheels & Bottom Half
- 4 wheels - 11 lbs
- 2 sawhorses - 36.5 lbs
- 2 sections of conduit/axle -1 lb
- 2 2x4 to support upper half - 12 lbs
To make the center hubs, 2 sizes of dinner plates were traced on lumber and a total of 8 were cut with a jigsaw. A pair of each size was glued, clamped and allowed to dry overnight.
Starting at the center of the hub and recognizing there are 360 degrees in a circle, 9 lines were marked 40 degree apart. These lines were then extended to the edge of the hub, allowing for 9 spoke holes to be drilled along the outside of the hub. The spokes were then glued into place and allowed to dry overnight.
3" plastic landscape edging acts as the rim for each wheel. After drilling a pilot hole where the edging meets the spoke, the two are secured with a larger wood screw. Both sides of the spokes and hubs are painted gold for accent.
Since the hearse wheels are not intended to roll or support any weight, they are attached to a pair of sawhorses by a 4' length of conduit. Before doing so however, the hub's center was enlarged to 1.25" and a corresponding hole was drilled in the sawhorse side support/gusset. Acting as an axle, a 48" length of 1" conduit can then be thread it all together (wheel-sawhorse-sawhorse-wheel). Finally, all 4 ends are kept from slipping with a cork that has been glued to the inside of a spray paint lid.
After painting the sawhorses a neutral/outdoor color and stapling painted plastic ivy to the sawhorses, the sawhorses will hardly show as they blend in with the landscape and the eye instead will see the gold wheels.
Once two 2x4's are placed on the sawhorses, the bottom half is completed and we can move on to building upper half of the hearse - known as the body/base...
Step 4: Base / Body & Upper Half
- Styrofoam Base - 12.5 lbs
- Particle Board Body - 33.5 lbs
- Mirror attached to Wire, Fabric, Dowel - 8.5 lbs
Using styrofoam adhesive, the blocks were bonded together and painted to keep from disintegrating. While the large styrofoam base may be a bit bulky, it is strong enough to support a flexible body made of hinged panels/frames and light enough to be stored in a crawl space.
With the exterior hearse body being slightly larger than the styrofoam base, it easily slips over and covers 2 sides of the foam. The exterior body consists of two side panels/frames that are hinged to (4) 1x4" slats. This hinged body fits over the styrofoam base, and allows access to the side of the hearse - which makes it convenient to hang the window/mirror and to fold/flatten up for storage.
The side panels each consist of a horizontal 1x6" that runs across the top and bottom, and are attached to particle board. On the side that is visible from the road, a 22" opening is added for the casket viewing. As mentioned, both of these side panels connect to the top by 8 hinges and (4) 1x4" slats which allows it to rest on the top of the foam body
In place of a window, a framed mirror is used in the casket viewing area so that anyone that wants to view the dead will see themselves. The mirror was outlined on the foam block, trimmed out, and another coat of paint was applied to the foam. Once dry, the hinged side panel is lifted and the mirror can be attached with wire and hung from the top slats (which rests on the top of the foam body).
Red fabric was gathered on the dowels and glued to the window/mirror. Cup hooks screwed into the inside panel of the top/bottom board hold curtain/dowel rod in place.
Thrift store sconces are then hung on the sides to provide the illusion of lighting and now the back of the hearse gets attention...
Step 5: Back/Top
- L-Shaped Moulding hinged to the Back Frame - 12 lbs
- Decorative Mirror attached to Wire, Fabric, Dowel - 7 lbs
- Pediment Topper - 1 lb
Another frame was hinged to the bottom of the part of the moulding that is seen from the back of the hearse, creating the appearance of back door. Again, the illusion of glass in the back door is accomplished by hanging another decorative mirror, in which red fabric has been glued around it and then secured to the back slat of the body with wire.
To hide the a slight gap that appears when the L-shaped section is placed on top of the body/base, upholstery trim was painted gold and stapled to the underside of the L-shape unit, providing additional detail to the bottom of the moulding. A removable pediment was also painted gold to help draw attention to the back of the hearse.
Step 6: Front
- Rein Holder, which were once sconces and are removable when storing
- Foot Rest, once part of exercise equipment but is now getting more use once it was painted black
- Side Finials, purchased from and after Christmas clearance aisle
- Red Curtains, gathered by dowels and used to cover the exposed front of the foam body
- Drivers Seat, or styrofoam covered with red fabric and accentuated with tacks.
Step 7: Success!
While I was excited to start the project, at first I wondered if I bit off more than I could chew. However, by breaking the project into a few manageable sections, I found I could work on one section until I ran into issues, and move on to something else until my brain recovered.
In otherwords, I didn't follow any specific order when building and tried to not get too overwhelmed. (Documenting this Instructable consumed far more brain cells.)
Until it's final week I wasn't sure how it would turn out, but by taking my time and stepping away from it every few days, the project was more successful than expected, and easily met all my criteria! (The only thing I would have done differently is to use plywood rather than particle board.)
In total the hearse weighs over 150 lbs, but by being able to break it down in to 4 main sections, and each of those into smaller units, the parts were very manageable from both a setup and breakdown perspective. Likewise, smaller units are easier to stash around than a unit that is around 5'x5'x4' when fully set up.
This year my cemetery will show the hearse in a parked position. Next year I'd like to create a skeleton team to pull it. In the meanwhile, I hope you will be inspired to contribute your hearse plans to the Internet and if so, I'd love to see them!
Second Prize in the
Halloween Decorations Contest
17 Comments
5 months ago
Hi! I'm not sure if you still read the comments, but I truly appreciate the consideration of breakdown and storage. I'm going to try something similar, but with a 6 foot foldable table I already have, instead of sawhorses. I welcome any suggestions on modification of your plans, since I'm also doing this with concerns about cost and space!
11 years ago on Introduction
Congratulations on your win too. :) this is such a fun website huh? I'm so glad my cousin told me about it.
Reply 11 years ago on Introduction
I totally agree...it really keeps my juices flowing. ;-)
Have a great ThankFestiChanuKwansMas holiday!
HaHa...Maybe i'll be remembered (on my tombstone) as the cray-z lady that always decorated for "Satan's Holiday"
The intro story is great. I hope you keep building on to your yard decorations and your place becomes the place for Halloween decorations in your neighbourhood!
Congratulations on being a finalist in the Halloween contest!!! Can’t wait to see if you win! Good luck!
Thanks for your positive vibes and sweet comment!
What a nice comment! ;-).
It's funny...what started out as an embarrassment has turned into a passion. Halloween is soooo much fun
Congratulations on being a finalist.I have my fingers crossed for you.I have horses and love Carriages and carts of all kinds and I love this one.Great job and I'm glad you didn't give up because of that neighbor .
Another great Halloween - you've topped yourself.
Something similar has been kicking around in my head for a couple years. My biggest problem is STORAGE, we already over fill a 20' box truck and a 12x14' shed so I read this with a LOT of interest and although it's not what I have pictured in my mind you've given me some great ideas.
I started building a winged demon horse last year to pull the soul chariot but the pvc I was using didn't work as well as I had hoped (unstable, sway backed etc) so I rethought the design and found a large wire frame reindeer which I'm redesigning now with an "ible" in the works. Of course it meant a rescaling of the entire project but that may work for the best since we are quickly running out of room for decorations outside the home HAUNT
Wow, you must have quite the haunt! I look forward to seeing your winged-horse "ible", especially since I want to build one next year.
I have several "ibles" on previous haunts and haunt related builds
You are so talented!! I absolutely love this! So happy to be following your posts! Steph :)
Thanks for your kind words. It was so much fun to plan & construct.
Creepy cool......how very creative! I can't imagine all the thought you put into this. I love following your latest artful endeavors. Thanks for sharing!
Looks to me that this belongs on an Artists site, vs. Craft -- though fine craftsmanship was certain not lacking!
It's obvious you enjoyed every step of the process and I imagine it was a labor of love that consumed (in a GOOD way!) hours of planning, researching, critical thinking, accumulating, etc. Thank you for taking great notes along the way and being willing to share your Sin-Eater with us.
I also appreciate your cost documentation -- nice touch! It showcases your resourcefulness by providing LOTS of creative alternatives!!!
