Introduction: Casino
This instructable will teach you how to make a simple casino building.
Step 1: Insert Shapes
drag a polygon and diamond into the work plane
by tapping on the polygon, change the sides to 12
make the polygon and diamond bigger
put the diamond on top of the polygon, make sure you can only see the top of the diamond
Step 2: Creating the Windows
drag a 'hole' box into the work plane
flatten the box, make sure the width of the box is thinner than one side of the polygon
duplicate the box and insert half of the box in the polygon
duplicate again and continue to put one above the other, repeat until there is 11 on one side
Step 3: Add More Windows
select all the windows you have and duplicate it
move the copy to another side of the polygon
repeat until you have windows on all sides of the polygon
then, you can merge everything together
change the colour to a light beige
Step 4: Adding Side Pillars
drag a box into the work plane
increase the height of the box, then make it thin
move the box to one corner of the polygon
duplicate the polygon and put one at each of the corners
merge everything and there you have it, a simple casino building
Step 5: Comparison
Here is the casino vs the real one for comparison
