Introduction: Cassata Alla Siciliano
This is my Nana’s recipe for a traditional Sicilian ricotta cake
that’s as good as it would be if a cannoli and tiramisu had a love
child. Nana used to make it every Christmas, and many years
later family and friends still talk about “Nana’s famous Cassata
cake.” It’s an easy no-bake recipe with seven ingredients, and it
only takes about 15-20 minutes to put together. Give it until
the next day to chill and set, and you’ve got a delicious and
decadent treat that will impress all!
Ingredients:
3lbs ricotta cheese
1 cup sugar
1tsp vanilla extract
¼ cup crème de cacao
¼ - ½ cup semi sweet mini chocolate chips
3 packages SOFT lady fingers (split) OR pound cake strips
Maraschino cherries (for decoration)
Step 1: Mix the Filling
If your ricotta has any liquid in it, use a cheesecloth or fine
metal mesh colander to strain any excess liquid out. Too
much liquid can cause the mix to set too loosely.
Combine the ricotta, sugar, vanilla, and crème de cacao in
a large mixing bowl. Beat with an electric mixer at medium
speed for 10 minutes – mixture should be fluffy.
Step 2: Add the Chocolate Chips
Fold in the chocolate chips – use a minimum of ¼ cup, but
you can add more if you like. I like to use ½ cup, but Nana’s
original recipe calls for ¼.
Step 3: Line the Springform Pan
Split the lady fingers as you work with them, lining an 8"
springform pan as pictured. Soft lady fingers will easily
come apart into two halves. Fresh lady fingers should have
a slight stickiness to them, so you can easily press them
into place as you line the inside of the springform ring –
place them so the outside of the lady finger faces the
outside of the springform pan. Lay lady fingers along the
bottom to get the whole floor of the pan covered – don’t
worry about the pattern.
Be careful NOT to get the crunchy cookie type of lady
fingers – they will not work in this recipe. If you cannot
find the right kind, you can get pound cake and cut it into
strips around the same size and thickness.
Step 4: Create the First Layer
Pour half of the ricotta mixture into the springform pan.
Keep the other half for the top layer.
Lay more lady fingers across the top of the mixture, again
covering the entire surface.
Step 5: Finish Top Layer
Pour the rest of the ricotta mixture into the springform
pan, over the layer of lady fingers. Use a rubber spatula to
spread it evenly.
Decorate the top with maraschino cherries and more lady
fingers, as pictured. Cover with aluminum foil and
refrigerate for a minimum of 8 hours, but overnight is better.
Step 6: Chill, Slice, and Serve!
Remove the springform ring. Cake should be firm and heavy, and the layers of lady
fingers will have soaked in some of the liquor.
Slice and serve – enjoy!!
Cheese Challenge
