Cast a Die (Or Dice)
Intro: Cast a Die (Or Dice)
I made a die out of metal for an end of the semester present for the best teacher ever. One of the best times in that class was when we illegally recreated the board game "Catan". She made photos copies of the cards and board and even laminated it. We had the some pretty awesome games I might add. She is moving now and I wanted to make something so she could remember 2nd period bio. So what better than a new die to put in our class game? This one's for you, Mrs. Jenny!
STEP 1: Cut Out Foam Casting.
Using a hot exacto knife or a foam wire, cut out the exact form or shape you want the final product to look like on some polystyrene foam. Don't add too much detail, as this is easier done once the metal is cast. You also want to make a small rectangle coming out of the top where you will be pouring in the molten metal. Submerge this into the sand cup until only the top of the rectangle is barely at the sand level. Your form is now ready to be cast.
STEP 2: Melt and Pour
I am using new pennies as the metal to cast with. It is easier to get and melt, and literally only costs a few cents. Also, the zinc won't rust like steel or iron would. When melting pretty much any metal, make sure to remove impurities, so take out the dark grey foil crap that ends up being in the mixture. This stuff actually burns, a beautiful blue, green and lime yellow but isn't very safe. you should be left with a large metallic bubble that is shiny. Heat this up to a nice viscosity and pour it on the top of the foam. The foam will burn away in seconds, leaving a beautiful casting of zinc in place. Pour out the sand into a container exposing the casting. Don't pull it out from the top as this can cause the still new casting to bend.
STEP 3: Clean It Up
Cut off any excess from pouring and begin to file down the rough sides. Use a rather fine file instead of course to add accuracy and precision to you finally product. After you are satisfied with the filing, begin to sand the a smooth finish. Be sure to get all rough edges and corners.
STEP 4: Add Fine Detail and Finish.
Add all the fine details you want and sand down will a fine grit. Finish it to a mirror with some ultra-fine steel wool. Congrats! Your done!
50 Comments
irish2ice 8 years ago
I wonder what pre-1982 pennies would come out looking like since they were primarily copper? A copper die?
EnzamusP 7 years ago
It would be a heck of a lot more difficult to do it though, copper is very finicky compared to zinc. Oxidizes and slags more regularly, needs more heat, eats steel when the crucible is made of it... copper sucks to cast with at hobby level. But in all fairness, it does look very pretty when it comes out.
sublingual 4 years ago
Ethan1023 7 years ago
I guess you could say it was "die-cast". Hahaha...
Ow... that one hurt...
You beat me to it ;)
Aaw psyche!
RichardS137 8 years ago
I believe there is a U.S. federal law against defacing or otherwise causing harm to United States money, including pennies. Be careful with what you do with your pennies!
HOUDINI2 7 years ago
It is not against the law in the USA to burn money or melt coins into something else. It is against the law to change a bill to a different denomination or to make your own currency, Look it up Richard S137, if you have the ability to reply on here then you have the ability to look it up, so why say " I believe " when you can look it up yourself ?
RichardS137 7 years ago
KellyD3 7 years ago
Really? Who cares.
imyxhuang 8 years ago
I'm quite certain it's legal for educational or recreational use.
You just can't do it on a massive scale in an organization for the purpose of getting cheap metal, though. (Although I doubt this is the cheapest way of getting metal.)
MimkeD234 8 years ago
The law prohibits changing the currency to look like a currency of a higher value. As in, I can't write a zero next to the one and say that I have a ten dollar bill. That would be illegal.
So long as you're not using the defaced currency as actual currency, you're not going to be prosecuted for it. And yes, the officials have come out and said as much. Check with the mint, they get this question all the time. (Besides, with this Instructable, all you have left is zinc. There's no way of proving that it ever came from a penny to begin with).
TankGirl1980 8 years ago
imcp1024 8 years ago
Nickw50 8 years ago
oxidasion is for copper, not zinc
Gadget93 8 years ago
zombie_hunter614 8 years ago
zach.thornton.750 9 years ago
How does the mold work? the sand is an insulator and does not melt when pouring molten zinc next to it?
starwarsgeek1 8 years ago
