Introduction: Casting a Concrete Lamp Sculpture With a CNC Milled Styrofoam Mold
In this Instructable I'll show you a quick and simple way to make a concrete sculpture with a CNC router and a lost styrofoam mold.
Step 1: CAD Design
- The CAD Model is just a quick sketch with a few arcs and lines to create a "flame"...
- I've used a 3D CAD and extruded the sketch to get a better idea how the final part will look like - but this is not really necessary for something that simple...
- Its size is about 500 x 420mm and you can download the "Flame.dxf" file here...
- Be aware: we're creating a negative mold - so the final part will be mirrored! In this case it doesn't matter - but if you e.g. add some text you'll have to mirror the drawing or the final part will be wrong!
Step 2: CNC Machining the Lower Part of the Mold
- The mold is made from two 600 x 600 x 50mm pieces of fine extruded styrofoam...
- Extruded polystyrene foam offers much better surface quality and more stability than expanded polystyrene foam (the one with visible beads). It is also extremely easy to machine. I used "Styrodur" from BASF, I think a similar material in the US is called "Roofmate"...
- The final sculpture will be 90mm thick - but unfortunately my longest end mill is too short for this so I decided to cut the two 50mm pieces separately...
- You can see the CAM process using Estlcam and machining of the material in the video at the beginning...
Step 3: CNC Machining the Upper Part of the Mold
- After the lower part has been finished the second 50mm sheet of styrofoam is just glued on top of the first using some spray glue...
- Make sure the glue you use is suitable for polystyrene - otherwise the mold may be destroyed because many solvents dissolve styrofoam rapidly...
- I've decided to glue before machining instead of later because this way the parts will automatically be aligned perfectly - there is no risk of displacements or distortions.
- CAM and machining is again shown in the video at the beginning...
Step 4: Inserting the Lamp Socket
- The lamp socket is a small E14 - a choice I regret somewhat because larger bulbs require E27 and may have looked better...
- The socket is just squeezed into the styrofoam with a little epoxy glue:
- Just press it against the foam where you like it to be...
- Then use a sharp knife to cut along the dent it created...
- And finally add a few drops of glue and squeeze it into its final position...
Step 5: Mixing and Pouring the Concrete
- Mix your concrete and make sure it is pourable but not too liquid...
- After pouring I've knocked a few times against the molds sides pretty hard. This way most air bubbles will rise to the top. I should have done this a bit more thoroughly as there are still some bubbles visible in the final part but fortunately not too large and not too many...
- Be aware that most concrete varieties really need a few days to harden even if they appear solid after a few hours. If you are too quick the sculpture may break during demolding. I've used cement screed and left it 3 days to harden...
- The back of the sculpture is quite rough - if you want it to look nicer you'll need to scrub it after a few hours with some water and a felt pad...
Step 6: Final Steps
- You'll not be able to remove the sculpture without destroying the mold anyways - so just take a box cutter and make a few relief cuts to make demolding easier...
- Add a few felt pads to the bottom to avoid scratching your floor or furniture...
- Then finally screw in a bulb and you're finished...
