Introduction: Castle Planter (with Tinkercad Code Blocks)
This design here took me quite a while to accomplish, and since my coding skills are, limited to say the least, I hope it turned out ok :) Using the instructions provided you should be able to completely recreate every aspect of this design without any outside help, skill, or knowledge. Every picture has the code on the side and when combined it will create the entire project!
you will probably need to click on the pictures to get the whole view. sorry.
Make sure on every step to look at the code in the picture it will get you a long way!
Hope you like it! :)
here it is in Tinkercad https://www.tinkercad.com/codeblocks/2VzJT7vCa4Q-the-statue-of-liberty-base-planter
Computer, and time thats about all you need.
Step 1: Step 1: the Base
pretty self explanatory
Step 2: Step 2: Cube With a Hole
just do the written code.
Step 3: Step 3; Again
This is step two over again, eventually we will miter the bottom one to the top with a pyramid.
Step 4: Step 4: First Bricks
the bricks are all in a row just do what the code shows. :)
Step 5: Step 5: First Circles
These are the first circles, just like the bricks they are in a row and you can copy the code.
Step 6: Step 6: Bricks
need I tell you to follow the code :) its the same thing but rotated 90 degrees.
Step 7: Step 7: Second Set of Circles
just like the first one, but rotated 90 degrees
Step 8: Step 8: What Do You Know! Its Bricks Again!
Its bricks again same old thing as the other two just do this one twice, and rate 180 degrees. Or follow the code :)
Step 9: Step 9: Bricks
This time you need to raise the bricks just above the first set. there are two sets here, and they need to be offset as the picture and code shows.
Step 10: Step 10; Bricks Row 2 Finish
finish off row two!
Step 11: Step 11: Bricks
well better get started on row three! noticing a theme.
Step 12: Step 12: Bricks Finish
Finally we get to finish the bricks! :) hurray. If you didn't lear from the last 100 times, all you have to do is follow the code :) lol
Step 13: Step 13: Miter It Off!
use the pyramid and cut the top. also get those edges aligned!
Step 14: Step 14: Circles Number 3!
well here we go again, same concept as the bricks same concept as the other two circles. ENJOY!
Step 15: Step 15: Circles Again!
Its the end of the circles you have been rotating them like crazy! :)
Step 16: Step 16: New Miter
follow the same concept as the last one, look at the code! :)
Step 17: Step 17: the First of the Pyramids
seeing a trend here! :)
Step 18: Step 18: the Second of the Four Pyramids.
enjoy doing it again rotate 90 degrees!
Step 19: Step 19: Pyramids
try for three!
Step 20: Step 20: Pyramid Finish
Just follow the code in the picture and you will be fine!
Step 21: Step 21: Tower
there appears to be a lot going on here, but there are actually few shapes stick to the code and you will be fine.
Step 22: Step 22: Support
again stick to the code! most of this is just for decoration. :)
Step 23: Step 13: Top and Windows
black the windows, and miter the top, makes it printable! :)
Step 24: Step 24: Crenelations
its just holes in the top! :) look at the code to decide what to do.
Step 25: Step 25: Decor
you are finally finished! great job! hope you loved this inscrutable. yes it should be 3D printable.
