Castle Out of Matches
Intro: Castle Out of Matches
You will need
-Matches
-Glue
-Working space
-Matches
-Glue
-Working space
STEP 1: Tower Base
Put 2 matches about a match width away from each other. Stick 8-10 on them in a perpendicular direction, add another layer like this.
STEP 2: Tower Walls
Add 20 levels of matches perpendicularly of 2 per level. Like this.
STEP 3: Tower Top
Add another level (the floor) of about 8-10 matches and another 4 levels of 2 the end result is this.
Repeat these steps another 3 times to make 4 towers.
Note: Sorry the image is not the right way up
STEP 4: Walls
Put 2 matches about a match width away from each other. Stick 8-10 on them in a perpendicular direction.
Repeat this step 12 times.
STEP 5: Attaching Walls Onto Towers
Stick one wall per tower; wait for the glue to dry the stick walls to the already stuck ones with 2 matches (into a 4 by 4 square). Like this.
STEP 6: Big Towers Foundation
Put 2 matches about a match width away from each other. Stick 8-10 on them in a perpendicular direction, add another layer like this. The end result should be this.
STEP 7: Big Tower Walls
Add 30 levels of matches perpendicularly of 2 per level. Like this.
STEP 8: Big Tower Top
STEP 9: Main Building
On paper draw an octagon the edges being the size of matches (except for 4 opposing sides which should be shorter). Place the matches in turns spreading out into a 2 match width length then connect them with matches. Build 20 levels of walls (first 4 opposing sides then the next)Like this.
Turn it upside down
Turn it upside down
STEP 10: Finishing Off
Stick towers to main building like this.
6 Comments
craig3 13 years ago
But is is pretty impressive work, i likes it
the glitch 9 years ago
wusupworld 10 years ago
griffin12345 13 years ago
but okay
bongo bongo 13 years ago
