Introduction: Cat Circle Container
This will be a tutorial on how to make a circle container with a subtle look like a cat.
Tinkercad
Step 1: Make a Sphere
Drag a sphere from the right tab onto the workplane
Step 2: Resize Sphere
Change the size of the sphere to your liking (I recommend keeping all sides equal for a perfect sphere)
Step 3: Making the Hole to Hollow the Sphere
Copy and past the sphere and click on the pasted one, then click on the hole option and scale it down by 3 on all sides
ex: 45 x 45 x 45 -> 42 x 42 x 42
Step 4: Making the Sphere Hollow
Drag a smaller sphere into the bigger one and make sure it fits perfectly inside without making any holes on the outside.
Once the hole is on the inside, group them together, making the inside hollow
Step 5: Make Cat Ears for the Sphere
Drag a paraboloid from the right tab onto the work plane
Shape the Paraboloid however you like to make it look like a cat ear I recommend: length 41, width 14 and height 17
Once you have done that, move the ear next to the sphere, then raise and rotate it to fit into the head Edit until they look like cat ears, group everything together
Step 6: Make the Top and Bottom Separate Parts
Copy and paste the already made cat sphere
Make two cube holes of equal size
Raise one of the cubes so that the bottom is equal to the top of the other (check the height of the other cube and raise it by that amount)
Group the hole to each cat sphere, make sure the two cat spheres are not grouped to each other though It should look like the last picture
Step 7: Make Connections to Connect the Two Together Once Printed
Make a cube and make the length and width 1
Put stick on one of the bottom cat sphere’s sides
Do the same on all 4 sides
Make holes on the top side of cat by duplicating the sticks that are solid and making them holes for top side, make them holes
Group everything together, and you are finished!
