Introduction: Cat Condo (DIY)
The cat condo is a homemade feline bed that is made from recycled materials. Its main structure comes from a cardboard box, which is a favorite item for most cats. It provides the perfect place for your feline to take naps in throughout the day.
- 2 wire hangers
- Pliers
- Duct tape
- Circular object (ex: bowl)
- Scissors
- Ruler
- Marker
- Cat bedding
- Safety pins
- 4XL T-Shirt
- Cardboard box (16 ½ x 18 ½ inches)
Step 1: Cut a Hole on One Side of the Cardboard Box
Use the scissors to cut the box. You can prepare the box to your liking. I cut off the flaps of the box to make later steps easier.
Step 2: Reinforce the Box
Reinforce certain areas of the box, you find flimsy, with duct tape.
Step 3: Cut the Hangers
Use the pliers to cut the hooks off the wire hangers.
Step 4: Bend the Wires
Bend both wires into a trapezoid shape.
Step 5: Build the Roof of the Condo
Poke a hole, with the wire, on an inside corner of the box, four inches down from the edge. Repeat this action on the opposite corner.
Step 6: Finish the Roof
Grab the second wire and repeat the process in step 5.
Step 7: Bind the Wires
Use duct tape to bind the wires to each other at the center. It should make a 'X' shape as shown in figure 15.
Step 8: Put the Shirt Over the Box
Pull the shirt over the box and place the head hole over the hole that was cut out in step one.
Step 9: Secure the Excess Pieces of the Shirt
Use safety pins, indicated by the white circles, to fasten loose ends of the shirt against the box.
Step 10: Place Cat Bedding
Place cat bedding inside the box. I overlapped the cat bedding to ensure the entire bottom was covered.
