Introduction: Cat Couch/Sofa
Hello,
Welcome to my first instructable, today I'm going to share with you an easy way to make a cozy couch/sofa for your little friend.
I hope you and your little friend like it.
Step 1: What You Need
1- A Cat.
2- Plastic Box.
3- Hacksaw.
4- Glue gun and hotglue.
5- 115cm x 36cm of velvet purple faux leather.
6- An old t-shirt.
7- Sewing needle and white thread.
8- Polyester cushion filling.
Step 2: Preparing the Box
Part 1:
Note: you can use a wooden box or any other box you want.
- First I took the plastic box and cut one of longer sides using the hacksaw, then I recut the sharp edges to make them smooth.
- I measure the length and width of the 3 sides left, then I took the faux leather and trace the measurement I got on it.
Measurement I got :
Two small pieces : 29cm x 18cm
One long piece : 47cm x 18cm.
I added 10cm to each part from both sides, the final measurement I got :
Two small pieces : 36cm x 34cm.
One long piece : 50cm x 34cm
(sorry for the long math I hope its not confusing , this numbers can change it depends on whats size of the box you have)
Note 2: you can measure one long piece 125cm x 34cm warp it on the 3 sides.
Part 2:
Now using the glue gun and a stick of hotglue, I started gluing the pieces of faux leather that I already cut to the plastic box, I put some glue in the bottom side of the plastic box then I warped the pieces around the box sides then glue them in the inside.
Step 3: Making the Pillow Cush
1- I measure the base of the plastic box and I got: 47cm x 28cm.
2- I took the t-shirt and I trace the measurement I got on it 47cm x 28cm, then I cut it to the lenght.
3- Using the sewing needle and thread , I did sew one side of the pillow.
4- I fill up the pillow with the cushion.
5- Lastly I closed the last side of the pillow by sewing it.
Step 4: The END
This is the final result! I hope you enjoyed this instructable, If you have any question don't hesitate to ask..
Thank you so much, see you soon.
