Introduction: Cat Tent Scratcher
Does your cat dream of camping in the wilderness? Make all their dreams come true and construct this kitty tent! Bonus--it doubles as a scratcher!
Drill
Phillips bit
Small drill bit for screws
Four 22" pieces of wood cut with a 22.5-degree angle on one end
Two 24" pieces of wood
2" screws
1 1/4" screws
24" by 48" rug
Step 1: Lay Out Cross Bar
Lay out two 2x4 pieces with the angled side facing up and pre-drill two holes for the cross bar.
Step 2: Screw in Cross Bar
Screw in the cross bar using the pre-drilled holes with the 2” screws. Repeat on the other 2x4 to secure the cross bar.
Step 3: Repeat the Process for the Other Side
Repeat the cross bar process with the other two 2x4 pieces.
Step 4: Stand Up Sides and Secure Together
Stand the two sides up together and screw the tops together with 1-1/4” screws. You can use wood glue as well for extra strength if you choose.
Step 5: Repeat on Both Sides
Repeat on both sides, securing the 2x4s together.
Step 6: Cover With Rug
Lay rug over the top of tent frame. Pre-drill holes if you wish, and secure the rug on the top, middle, and bottom of one 2x4 with 1-1/4” screws. Repeat on each of the other three 2x4 pieces.
Step 7: Go Camping!
All finished! Send the kitties camping (and scratching)! Spray with catnip spray for extra fun.
