Introduction: Cat Toy 1.0
I made this cat toy because we go out a lot and my kitten is bored so i made her a cat toy that when ever we leave we can turn it on and she can play with the toy. This cast toy is easy to make you just need to follow these steps and you will succeed.
You are probably wondering what do I use to build this cat toy? Or why my cat is so cute? my cat is so cute because she is a Scottish fold (fluffy).Any ways I used A lego Mindstorms EV3 educational Lego set.
Step 1: 1st Part
Do this add the two motors and the gray stick thing.
Step 2: 2nd Part
Do this add the black axel and the gray pegs to connect the two motors.
Step 3: 3rd Part
Do this get the brick and add these connecting pieces
Step 4: 4th Part
Do this add the black pegs.
Step 5: 5th Part
Do this add the gray stick with holes. then add the black pegs
Step 6: 6th Part
Do this connect the two parts
Step 7: 7th Part
Do this add the support like shown
Step 8: 8th Part
Do this now lets test it and see if it can stand.
Step 9: 9th Part
Do this to the motor add the two gray pegs and add a white piece
Step 10: 10th Part
Do this use the two black pegs place them into a hole near each other then put an other white stick
Step 11: 11th Part
Do this now you can make it sort or long if you want just repeat the process.
Step 12: 12th Part
Do this find something that can attach and then attached it to the white hole thing(use something that hangs)
Step 13: 13th Part
Do this get ready to attach whatever you want.
Step 14: 14th Part
It's finished you just need to code what ever you want it to do for your cat and it will be done or copy this code and play with your cat.
