Introduction: Cat-proof Birdbath
In this Instructable we will make a birdbath that (hopefully) will be immune to unwelcome feline attention. To do this we will use:
1 tree
2 London taxi-style hubcaps, as found on the verge
1 bolt
1 washer
1 tube of silicone
Assorted standard tools
1 tree
1 bolt
1 washer
1 tube of silicone
Step 1: Cut Down a Tree
Well, not exactly 'cut down', but it certainly won't be buying you a drink next time you meet.
Essentially we're looking for a tall post that will prevent cat-pouncing, well anchored to the ground. Sounds like the first 10' of a birch tree... We had a suitable candidate, a beautiful tree, but sadly its root system was starting to destroy our pathway.
Step 2: Trim the Tree
We need something vaguely horizontal, otherwise the water'll fall out, so trim the tree to give a nice, neat, horizontal post.
Step 3: Drill a Hole in It
Now we need to drill a hole so that the bird bath can be securely fixed in place. Might as well drill a hole in one of the taxi hubcaps at the same time...
Step 4: Cut the Hubcap Down to Size
This hubcap is the connection to the tree, it has a hole in it (so far), now let's cut it down to a frisbee-esque disc that'll form a good base for the other hubcap (oh yes, you'll need two)...
Step 5: Wash the Hubcaps
You can't have a dirty birdbath: the wee sweeties'll sicken. So wash those hubcaps.
Step 6: Make the Base Neat
Purely a cosmetic detail, but let's make it nice.
Step 7: Base & Bolt
Base, bolt & washer ready to fix to the tree
Step 8: Fix It to the Tree
Now bolt the base to the tree
Step 9: Silicone the Base
The base gets siliconed generously, so as to adhere securely to the second hubcap
Step 10: Squidge on the Second Hubcap
Press the second hubcap onto the remains of the first.
Use a spirit level to try and get it reasonably horizontal.
Step 11: The Enemy
Know locally as the devil
Step 12: Admire
Ok, it's a bit silver
Step 13: Fill It With Water
It's time to fill the birdbath with water.
Step 14: Postscript
It's a few months since the installion of the birdbath, it's been quite popular with the birds.
The main problem with it is cleaning & refilling it, which I need to do atop a set of steps.
The tree has regrown a surprising amount
