Introduction: Catapult Basketball
Hey today I will be making a catapult basket ball court and hoop. For this you will need Popsicle sticks, rubber band, foam pieces, foam board, paint, chopsticks, wood, scissors, and hot glue.
Step 1: Gather Your Materials
Popsicle sticks
3 oz cup
Foam board
3D printed basketball hoop
Chopsticks
Wood
Paint
Rubberband
Foam beads
Step 2: Build Your Catapult
Step 1: Make two lines with two Popsicle sticks each then put one over the middle and use hot glue to glue it.
Step 2: Break two Popsicle sticks in half.
Step 3: Then put the half's at the ends of the two Popsicle stick ends and connect them.
Step 4:Then glue foam pieces to the middle of the catapult outline.
Step 5: Break 2 popsical sticks in half.
Step 6: Attach foam pieces in top middle of two half's.
Step 7: push chopstick through bottom foam pies also add foam piece in the middle. Step 9: Make firing arm by attacking foam piece Popsicle sticks and cup together by using hot glue.
Step 8: Attach rubber band.
Step 3: Build Your Court
Cut foam board to 20 by 12 then design how ever you like. Then make hoop by getting some chopsticks foam board and wood. then drill two holes in the wood that are chopstick size. Then put the chopsticks in the holes then attack a 3 by 1 inch foam board design back board then attack a hoop of material choice. then attach to court.
