Introduction: Celestial Trinket Tray
Heyya,
This instructable is about Celestial Trinket Tray using Epoxy Resin AKA Liquid crystal... Once i started working with resin, I'm kinda obsessed with it, because its so damn good medium with of course with proper safety measures. Today let's make this celestial trinket tray/dish together.. This is beginner friendly procedure so watch and just enjoy the process
Step 1: Supplies
1) Epoxy resin - 135g & Hardener - 45 g
I used epoxy resin and hardener ratio of 3:1
2) Moon phase silicone mould
3) Oval Trinket tray silicone mould
4) Powder pigment - I prefer pearly colours for creating galaxy effect
5) White holographic glitter
6) Paper cups
Safety Measures
1) Respirator
2) Gloves
Step 2: Shimmer
For moon phase mix 21g resin & 7g hardener until cloudy becomes clear, once its transparent add white holographic glitter
Step 3: Shimmer Moon
Pour the shimmer magic into moulds and let it sit for 24 hours
Step 4: Demould the Moons
After 24 hours once its cured, glitter will slowly settle at the bottom of mould, so the shimmer part is facing other side. Let's demould and take a look.
Step 5: Phase 2
Again mix a limited amount (approx 10gm) of resin apply on the front side of moon and stick on the trinket tray with equidistance between
Step 6: Galaxy Colours
Mix resin and hardener now , Mix 105 g resin and 35 g hardener
Step 7: Galaxy Pour
Here comes the most fun part.. Yay !!
Main reason behind fixing moon is since its fixed prior so that adding epoxy resin will not change the moon position.
Lets begin pearl black, Everthing here on is random, so really the process while making, no patterns or no restrictions to bound your imagination.
Try to scatter colours in different places as possible
Step 8: Blending
After pouring all colours and filling the trinker mould, take a hair dryer or heat gun and give a blow.. You can see the blending happening. This helps in combining all the colours and give a galaxy finish.
After the blow you can see your own milky way galaxy in second image
Step 9: Design
As you can see, after the blow it has formed its own colour too.. and also you can see effects near the moon
Step 10: Cured
After 24 hours its fully cured now, you can demould it.
Step 11: Thank You !!
Thank you for coming this far, hope you enjoyed the making process.
Another shell trinket made with similar galaxy pour except the moon phases
Please let me know your thoughts and suggestions in comment section
If you wanna, do share a pic , would love to see your galaxy version
