Cement Grim Reaper
Intro: Cement Grim Reaper
Every year I like to try and make new Halloween decorations for my niece. This year I wanted to try and make a cement grim reaper to go on the porch. I also have a website Unique Creations By Anita where I share unique projects that you make from mainly recycled materials. So you will notice that I used mainly recycled materials in this project too, but you can adapt your materials.
STEP 1: Gather Your Supplies
I used a spindle as the main support but any 2 x 4 piece of wood will work. You will also need some chicken wire to make the shape and a bag of skeleton bones. I bought a bag a few years ago from a budget store for less than $10 and reuse them each year to create new projects. If you missed last years project I created a Halloween flower arrangement. For the base of the stand, you will need a heavy chunk of wood to support the weight of the cement grim reaper.
STEP 2: Make a Base
Start by drilling a hole in the base and slightly countersink the hole so the base is stable once the screw is inserted. Next, predrill a hole into the spindle, then screw the spindle to the base from below. You can also add some wood glue for extra support.
STEP 3: Add the Head
The idea is to have the head attached to the top of the spindle. To achieve this, I cut an X shape into the bottom of the skull and pushed it down onto the spindle.
STEP 4: Making the Grim Reaper Shape
I used some chicken wire to make the shape of the shoulder for the towel to be draped over. The “Arms” were created using scraps of wood that I screwed into the spindle.
STEP 5: Making the Grim Reaper Cloak
I mixed some cement with water and mixed it until I got a running consistency. To protect the skull from the cement I added some saran wrap around the skull before draping the cloak. To make this project easier if you have some black colour pigment I would recommend adding it to the cement now.
STEP 6: Cover the Towel in Cement
I pushed the dry towel down into the cement and realized straight away that was a mistake. The towel just sucked up all the fluid and the cement did not stick. I would recommend wetting the towel before putting it into the cement mixture, which I did after the fact.
STEP 7: Drape the Towel
I would also recommend protecting the floor and stand from the cement drips with plastic or scrap fabric. Once the towel has been completely covered in the cement you drape it over the form and shape the cloak as desired.
STEP 8: Leave to Dry
You will need to leave the cement to dry overnight. I had all intentions of painting another layer of cement over the cloak the next day to make it stronger, but mine was solid. If your cloak still has any movement you can make up another batch of cement and paint it over the surface with a paintbrush. I wanted the cloak to be away from the face, so I used items I found around my shed to hold the cloak in place while it dried. These were removed before the cement was totally set, I was afraid I would not get them out otherwise.
STEP 9: Painting the Cement
Painting the cement was not as easy as I thought it would be. I used black spray paint and had to apply about 4 coats to the surface. The cement seemed to absorb the black colour and the grey colour kept coming through. This is the reason I recommended adding black colour pigment to the cement. I painted the stand black to blend in with the grim reaper. Once the paint was dry I removed the plastic from the skull.
STEP 10: Adding the Hands and Feet
I used the hands and feet that came in the bag of bones and attached them to the grim reaper using hot glue. To make the bones look a bit old and worn you can paint them black and wipe off the excess. The black will stay in the grooves giving the hands that dirty look. To finish the look you can add some accessories like the pumpkin and the trick or treat sign.
STEP 11: More Great Project
This tutorial will show you how to recycle an old wine barrel into a table with built-in wine bucket.
STEP 12: 3 D Halloween Mirror
Another cool Halloween project is this creepy 3 D Halloween skull mirror.
