Introduction: Cepelinai (Lithuanian Stuffed Potato Dumplings)
I've been lucky enough to spend a fair amount of time in Lithuania since 2009. Often my trips have been almost too much fun. Like most northern countries the traditional food is hearty, filling, it uses a lot of root vegetables/meats and abstains from spice. My second favorite Lithuanian dish of all time is Cepelinai (pronounced Szep-eh-lin-aye). They are a lot of work to make, the texture is strange/dense/gluey, they are incredibly heavy and though I would normally consider these qualities negative, I love them when it comes to Cepelinai...especially in the cold and dark of winter.
Their name Cepelinai (zeppelins), comes from their shape which resembles the antiquated airships.
What you will need to Cepelinai:
You will also want a food processor, a large pot for boiling and cheese cloth or some other fine cloth for straining the water from your potatoes.
- 10kg potatoes (you don't want to deal with any less)
- Citric acid tablets
- 1 to 1/2 tbsp salt
- 1 cup sour cream
- 1 kg ground pork
- 1 red onion, diced finely
- 1 beaten egg
- 1 tsp salt
- Black pepper to taste
- 1 kg curd cheese/ricotta
- 1 tbsp caraway seeds
- 1 beaten egg
- 1/2 tsp sugar
- 1 tsp salt
- 1 kg carrots
- 1 beaten egg
- 3 tbsp poppy seeds
- 1 tsp salt
Step 1: Exfoliating Potatoes
Peel all of your potatoes and then rinse them.
Step 2: Liquefying Potatoes
Puree all of your potatoes in the food processor. While you are pureeing the potatoes, every so often puree a citric acid pill with them and stir the mixture; if you do not mix citric acid with your potatoes, they will oxidize and your potatoes will turn brown/pink.
*If you do not have a food processor, and cannot borrow one, you can boil/mash the potatoes.
Step 3: Squeezing Potatoes
At this point you should have at least 10kg of potato slop (minus the weight of the potato skins).
You're going to want to double-up your cheesecloth and lay it over a pot or bowl. Ladle in 1-3 spoonfuls of the potato slop into the cheesecloth and squeeze all of the moisture out of the potatoes until it is a dry, fibrous and almost dough-like.
Make sure not to throw away any of the liquid, we will need some parts of it later. Continue to remove the liquid from the potato slop until you have worked through all of it.
*Check out the pictures if the explanation wasn't clear.
Step 4: Straining Potato Juce
Wash your cheesecloth and lay it atop an empty bowl or pot. Strain the potato juice/liquid through the cheesecloth. There should be some yellowy or whitish stuff in the cheesecloth and at the bottom of potato juice/liquid container, add this to your dry potato mixture. Repeat this step once more with the potato juice/liquid you just strained. Strain all of your potato juice/liquid. The white/yellow stuff you are salvaging is starch which you squeezed out of the potatoes.
After you've strained all of your potato juice/liquid two times, you may throw it out.
Thoroughly mix 1/2 to 1 tbsp of salt and the potato starch you just saved with your dry potato dough. The dough be quite mold-able at this point. The weight of dough you should have now should be way, way less than the original amount of potatoes you started with.
Step 5: Fillings for Potatoes
Now, if you haven't already prepared your filling(s), you should mix together at least one of the following lists of ingredients:
- For a traditional meat filling, combine the following ingredients:
1 kg ground pork
1 beaten egg
1 tsp salt
- For a traditional cheese filling, combine the following ingredients:
1 beaten egg
1/2 tsp sugar
1 tsp salt
- For a traditional (but almost forgotten about) vegetable filling, combine the following ingredients:
1 kg carrots
1 beaten egg
3 tbsp poppy seeds
1 tsp salt
1 kg ground pork
1 beaten egg
1 tsp salt
1 beaten egg
1/2 tsp sugar
1 tsp salt
1 kg carrots
1 beaten egg
3 tbsp poppy seeds
1 tsp salt
Step 6: Fill a Potato
Set some water to boil in a pot, enough to just cover a whole potato. While your waiting for the water to boil...
Gather some of your potato dough in the open palm of your hand so that, when flattened, it should approximately cover your palm. Spoon some of your desired filling into the center of the potato dough and fold the edges over the filling so that the filling is completely encased by potato. Roll your filled potato-dough ball into a spheroid or zeppelin shape.
Test your first Cepelinas by placing it in the boiling water. Boil it for 10-15 minutes. If it falls apart, you will need to mix in some flour with the potato dough because the dough is too wet. If it doesn't fall apart, you get to eat that Cepelinas (with some sour cream).
Step 7: Fill More Potatoes
Assemble and roll more Cepelinai until you run out of dough.
*to know what filling is in which Cepelinas, you can roll them differently. For example I roll the meat filled ones as a normal ball, and the curd or carrot ones as a zeppelin. You can also use your thumb to make an indentation in the Cepelinai to mark one filling from another.
**I really like when they Cepelinai oxidize a little bit, they start to look like raw potatoes again.
Step 8: Boil Some Re-formed Potatoes
Boil your Cepelinai for 10-15 minutes. A large pot can old many Cepelinai but you will want to make sure not to overcrowd them because they will be more likely to break apart, they will be harder to get out, the water will be starchier and so the finished Cepelinai will have more of a sticky and unappetizing goo on their exterior.
If you don't want to eat all of them, you can freeze the uncooked Cepelinai and boil them later.
*A portion for an average woman is between 2-4 Cepelinai.
**A portion for an average man is between 4-6 Cepelinai.
***A portion for the average child is between a man's and a woman's.
Step 9: Eat Some Deconstructed and Re-formed Potatoes
Your Cepelinai are ready!
Serve them with sour cream, chopped green onion. It is traditional to make a sauce out of cream/bacon/onion/mushrooms and top the Cepelinai and/or also to spoon some mixture of finely crumbled bacon/liquid fat over the Cepelinai.
Enjoy and stay warm.
