Ceramic Spoon Rest & Utensil Holder
Intro: Ceramic Spoon Rest & Utensil Holder
This past year my daughter moved and I thought it would be fun to make her something for her new kitchen....so I made her a spoon rest and utensil holder using clay and leaves.
STEP 1: Supplies
clay, I used red grog cone 06
clay cutter
rolling pin
leaves
slip
glazes
9Z
X15 cardboard template
leaves etching tool
glaze brush
Kiln
clay cutter
rolling pin
leaves
slip
glazes
9Z
leaves etching tool
glaze brush
Kiln
STEP 2: Spoon Rest
choose leaf to use for spoon rest and roll clay large enough to fit shape.
STEP 3:
press the leaf into the clay, run your fingernail gently along the veins of the leaf to indent them into the clay
STEP 4:
using the etching pin cut away the excess clay from around the leaf.
STEP 5:
STEP 6:
Carefully remove the leaf
from the clay
from the clay
STEP 7:
STEP 8:
place the clay leaf shape on a drying board, roll small
pieces of clay and put them under the edges of the leaf to give it the shape of a fallen leaf.
STEP 9:
STEP 10:
when the clay is leathery or has begun to harden I smoothed the edges with a small sponge
STEP 11: Utensil Holder
Roll large enough piece od clay to cut the 9X15 shape.
STEP 12:
STEP 13:
For clay into a cylinder shape, set aside
STEP 14:
roll a large enough piece of clay to place the cylinder on to cut base.
STEP 15:
use tool to cut clay for base, give about 1/2 inch around bottom.
STEP 16:
reach inside cylinder and with finger tips apply pressure from the inside of the holder, then using a finger push the clay up on the outside edge to secure the base of the utensil holder.
STEP 17:
roll more clay and begin to press more smaller leaf shapes into the clay, again use fingernail to apply pressure to get veins indented into clay.
STEP 18:
STEP 19:
cut the shapes from the clay, remove the leaf, if it rips or gets stuck it is okay it will burn off in the kiln
STEP 20:
Using slip, (liquid form
of clay, it acts like glue on the wet clay.) smear the leaf shapes and attach to the cylinder
STEP 21:
STEP 22:
This is a fig leaf from my daughter's Great grandfathers' fig tree!
STEP 23:
the leaves can overlap
STEP 24:
I use a bit of water on my finger to smooth the rough edges of the leaf shapes.
STEP 25:
If slip squishes out a paintbrush
can be used to clean up the wet clay.
STEP 26:
STEP 27:
STEP 28: Glaze
When pieces are thoroughly dry , fire to a bisque ware in the kiln, I used an o6 cone.
STEP 29:
I used clear glaze
for the inside of the utensil holder. I poured it in and out. I like the clear glaze on the red
clay, it looks very earthy.
STEP 30:
I chose an overglaze called speckled brown for the outside of the Utensil Holder
STEP 31:
and the spoon rest
STEP 32: Final Firing
The pieces are fired again in the kiln and ready to wrap for the holiday gift giving.
poofrabbit 11 years ago
