Introduction: Indoor Chamball
Indoor Chamball is a dodgeball-like sport played in a small indoor court.
If you like what you see here, we've also invented an outdoor team version that includes a new rope swinging mechanic for demolishing your foes. Check it out at chamball.org .
Object of the Game
Deplete your opponent's points by hitting them with the ball anywhere EXCEPT the elbows to fists and knees to feet .
Let's get started...
Object of the Game
Step 1: Preparation and Supplies
Before you can play Indoor Chamball, you need a couple of things.
1.) A size 3 soccer ball. It's like an indoor or kids soccer ball.
2.) A squash court - for a nice tight game with lots of ricochets.
OR
A racquetball court - for a more endurance and strength focused game.
3.) A lot of water...preferably beforehand...it's gonna get hot in there.
4.) OPTIONAL boxing hand wraps to protect your knuckles and wrists.
That's it! Let's Begin.
OR
Step 2: Beginning Play
Fundamental Rule
Both players may only hit the ball with the protected places of the body. These are the forearms to fists and knees to toes.
Beginning Play
One player stands in the left starting area and the other player stands in the right. They each have 10 points to start. The older player serves first.
Service
The server tosses the ball up and strikes it at the serving wall above the bottom serving line. As soon as the ball is struck, both players are free to move to any position on the court. The server may not touch the ball again until the other player has done so.
Moving on to Active Play
Beginning Play
Service
Step 3: Active Play
Active Play
While the ball is bouncing, it is in Active Play and can be hit by either player after it is touched by the non-server. If at any time the ball stops bouncing and rolls for over three consecutive seconds (roll-out) or stops at all (ball-stop), Active Play stops, and the last player to touch the ball re-serves. If there is a roll-out or a ball-stop after a serve, the non-server becomes the server.
No points are lost for a roll-out or a ball-stop
On to Scoring, the meat of the game!
Step 4: Scoring
Scoring
If either player touches the ball with any unprotected place at ANY TIME AFTER SERVICE, play stops, the player who was touched loses a point and the other player re-serves the ball.
Very simple.
Once a a player loses their last point, the game is over and the other player wins.
Now for Penalties
Very simple.
Now for Penalties
Step 5: Penalties
Time Limit
The overall game has no time limit. If the ball has only touched one player for 60 seconds after a serve, that player re-serves the ball.
Miss-serve
If the ball touches a surface other than the starting wall first on a serve, the serving player re-serves. If they miss again, they lose a point and the other player re-serves.
Illegal interception
If the server touches the ball first after they serve, they lose a point and re-serve to the other player.
Trapping, Palming, and Pushing
If a player hits the ball with their palm, traps it on the ground or with their body, catches it, throws it, or pushes it, they lose a point and the opposing player re-serves. As a rule, players should make sure that every bodily contact with the ball is a strike with a protected area and lasts for less than a second. Any other kind of contact is a foul.
Miss-serve
Step 6: Penalties Continued
Wall hugging
No sustained contact with walls or corners. A single warning is given and the player loses a point for each occurrence on subsequent wall hugging fouls.
Aggressive Contact
-Incidental minor contact is inevitable and not penalized.
-Bodily contact with another player that lasts for longer than one second is penalized with a stop of play, separation, and a re-serve from the player who hasn't touched the ball last.
-When a moving player collides with a static player, the moving player is at fault.
-When two moving players collide, the person who hasn't touched the ball last is at fault.
-Punches and kicks that land on the opponent are the fault of the assailant.
In all of the above cases, the player receives a single warning with no loss of point.
Upon subsequent fouls, the player loses a point for each occurrence.
If the sustained bodily contact, collision, or strike to the body has injured a player beyond the point of continuing play, the assailant has lost the game.
That's it! Play safe!
Aggressive Contact
