Introduction: Chair Companion
A Chair Companion is a small table which is useful to keep items handy while seated, such as a remote control or a drink. This Chair companion is low cost, light weight and easy to make.
The simple version of the chair companion is made here using 4 balloons. A larger one can also be made using 12 balloons, with each tetrahedral group of balloons supporting a corner of the table top.
Cardboard
4 balloons
Invisible tape
PVA glue
Step 1: Table Top Part 1
To make a table top for the Chair Companion:
- Measure a triangle on a piece of cardboard by making a couple of 30 centimeter arcs with a ruler and pen
- Draw the triangle
- Cut using a craft knife
- Make two triangles for added strength
Step 2: Table Top Part 2
- Glue the two triangles together, one on top of the other using PVA glue
- Have the corrugations cross each other for added strength
Step 3: Making the Base
The base is made from four partially inflated balloons:
- Blow up a balloon to about 15 centimeters in diameter
- Blow up another 3 balloons to the same size as the first one
- Attach the balloons together to form a small tetrahedral using invisible tape
Step 4: Attach the Table Top to the Base
The cardboard table top is attached to the base using invisible tape:
- Lay 3 strips of invisible tape across the cardboard, so about 20 centimeters of tape extends free
- Position the balloon base on top so the apex of the tetrahedral is touching the cardboard
- Attached the free pieces of invisible tape to the balloons - use a little tension
- Wrap a piece of invisible tape around the balloon base to keep everything together
Step 5: Ready for Action
The Chair Companion can now be used to keep useful items close at hand while sitting in a chair.
