Introduction: Chair Detector
Students in the elementary school are often tripped by the chairs and get injuries. We should make a machine for the teacher that could help the students to have the habit of moving their chairs under the desk before they leave the classroom. Teacher could turn off the device when the class started, so it won't make any noises. When the bell rings, the teacher will turn on the device by pressing the switcher that is connected to the Leonardo board. The ultrasonic sensor will detect whether there's chair between the desk and the floor. If the distance is more than 10cm than the device will have the red light on and the speaker will make some noise to remind the student. Otherwise, the green LED is on and the speaker won't make any noises.
By 5qn_
Step 1: Materials
Electronics:
- 1x 3W 4Ω TR-066F Speaker
- 3x 1/4W 82Ω resistor
- 1x 1/4W 10kΩ precision resistor
- 1x Ultrasonic sensor HC-SR04
- 1x Green LED 5mm
- 1x Red LED 5mm
- 1x White LED 5mm
- 1x Switcher 20mm*15mm
- 13x Jumper wires
- 13x Dupont wires 20p, double heads
- 1x Arduino board (Arduino Leonardo)
- 1x Breadboard
- 1x USB cable
Hardware:
- 1x 20cm* 30cm cardboard
- 1x 13cm*23cm*7cm paper box
Tools:
Hot melting glue gun, Soldering gun, Utility knife, Ruler
Step 2: Box Cutting
Tools:
Holes on the top of the box:
width*height
- 2cm *1.5cm / switcher
- 1.8cm*1.7cm / speaker
- 4.5cm*1.5cm / ultrasonic sensor
Holes on the left of the box:
- 1.5cm*0.7cm / USB cable
- 1cm width *0.1cm hight x3 / LED light
Step 3: Box for Botton
Tools:
Electronics:
Jumper wires
Steps:
3.1
Top cover
4cm*3cm and a 2cm*2cm hole
3.2
Left and the right part
3cm*3cm
3.3
Back and the front part
3cm*4cm
3.4
Button part
4cm*3cm
1cm from the left and right and dig a small hole for the wire
Step 4: Wiring
Electronics:
- 1x Green LED 5mm
- 1x Red LED 5mm
- 1x White LED 5mm
- 13x Jumper wires
- 1x Breadboard
PinMode:
const int pingPin = 7; // Trigger Pin of Ultrasonic Sensor
const int echoPin = 6; // Echo Pin of Ultrasonic Sensor
const int speaker = 2; // DigitalPin of speaker
const int greenLight = 13; // Green LED Safe
const int redLight = 12; // Red LED Too close
const int activeLight = 11; // White LED Start sensor
const int button = 8; // Active button
Reminder:
Stick LED, speaker and ultrasonic with hot melting glue gun
Step 5: Arduino Codes
This part of the codes calculate the distance :
inches = microsecondsToInches(duration); // Microseconds to inches
cm = microsecondsToCentimeters(duration); // Microseconds to cm
long microsecondsToInches(long microseconds) {
return microseconds / 74 / 2; // MicroSecond to inches
long microsecondsToCentimeters(long microseconds) {
return microseconds / 29 / 2; // MicroSecond to cm
This part of the codes print the distance on the monitor :
Serial.print(inches); // Print inches
Serial.print("in, ");
Serial.print(cm); // Printf cm
Serial.print("cm");
Serial.println();
This part of the codes had the main function :
buttonState = digitalRead(button); // The function will activate only when the switcher is on. If the switcher is off, the rest of the function won't work
if ( cm <= 10 ){ // Chair in
digitalWrite(13, HIGH); // Green on
digitalWrite(12, LOW); // Red off
}else{ // Chair out / dangerous
digitalWrite(13, LOW); // Green off
digitalWrite(12, HIGH); // Red on
tone( 2, 440.0, 100.0 ); // Speaker on
} delay(100);
Step 6: Adjusting Ultrasonic Sensor Distance
You can adjust the number in the if statement to other numbers. Click the tool and click the serial monitor, you can see the distance shown on the monitor.
Step 7: Video
Enjoy !!!
