Introduction: Change Android Runtimes
In this instructable I will show you how to change from Dalvak runtime to the ART runtime.
Benefits of changing
better performance
a felling of accomplishment
NOTE THIS ONLY WORKS ON Android 4.4.4 I DONT KNOW ABOUT 5.0.2
better performance
Step 1: Enable Developer Settings
Goto about phone then go down to Build Number and tap it until it says your a Developer that's it.
Step 2: Change Runtimes
Now goto developers options click Runtime then choose your runtime then reboot and your done!
Step 3: The ART RUNTIME
Android Runtime (ART) is an applicationruntime environment used by theAndroid mobile operating system. ART replaces Dalvik, which is the process virtual machine originally used by Android, and performs transformation of the application'sbytecode into native instructions that are later executed by the device's runtime environment.[1]
Unlike Dalvik, which since Android 2.2 "Froyo"uses just-in-time (JIT) compilation to compile the bytecode every time an application is launched,[2] ART introduces use of the ahead-of-time (AOT) compilation by performing it upon the installation of an application. By reducing the overall amount of compilation that needs to be performed across the operation of an application, a mobile device's processor usage is reduced and battery runtime is improved. At the same time, ART brings improvements in performance,garbage collection, applications debuggingand profiling.[1][3]
To maintain backward compatibility, ART uses the same input bytecode as Dalvik, supplied through standard .dex files as part of APK files, while the .odex files are replaced with Executable and Linkable Format (ELF) executables. Once an application is compiled by using ART's on-device dex2oat utility, it is run solely from the compiled ELF executable; this approach eliminates various overheads involved with JIT compilation, but it requires additional time for compilation when an application is installed, and applications take up slightly larger amounts of space to store the compiled code.[1][3]
A technology preview of ART debuted as an alternative runtime environment in Android 4.4 "KitKat".[4][5] In the next major Android release, Android 5.0 "Lollipop", Dalvik was entirely replaced by ART.[6]
FROM Wikipedia
FROM Wikipedia
