Introduction: Change Inverter in LCD Desktop Screen
So, you have turned your computer on, and then saw it start up as usual but then suddenly it went blank. So you decide to restart it for some odd reason, but then figure out that there is a problem.
Your problem is: The Inverter (connects the power to the bulb) is dying.
Your solution is: Open up you LCD panel and change the inverter.
Continue with this instructable to fix your screen.
Step 1: Open Up the LCD Screen
Take you screen turn it over and unscrew all the back screws. then carefully take of the back plastic panel, it is usually gripped on very well, so i would recommend taking two flat screwdrivers and slowly prying it open.
Step 2: Underneath the Plastic Panel
Most LCD screens are very similar, but some have the inverters beneath a safety metal panel and some have them on the bottom lower part of the LCD.
Detect where yours is.
Step 3: Remove the Inverter
This is the most dangerous part of the whole operation, be CAREFUL!
Take of the power connectors from the inverter, unscrew the inverter from the metal panel and place it in a safety Ziploc bag.
Caution: The inverter has literally thousands of volts inside it - and if you touch the wrong part you are toast!
The rest of the instructable will come when my NEW inverters arrive to my house...Good luck!
