Introduction: Change Your Favorite Book Into a Bag
Once I found this wonderful book at the flea market. It described the lives of people all over the world during one day. After a couple of years the book started to collect dust. Still I couldn’t get rid of it because I liked the cover so much. Time to make something useful of this book: a bag.
Step 1: Take Out the Inside
What you will need to make a book bag:
- a book
- a box cutter
- a ruler, scissors, pen
- paint and pencil
- double adhesive tape
- wood to make the frame, wood glue, band saw
- pillar drill, planer (if needed)
- two hinges
- fabric
- handle, sholder strap, hooks,
- press fasteners, tools to mount the press fasteners
- leather strap, screws
Do your books collect dust too? Make a bag and follow this instructables.
Take a book with a hard cover
Take away the pages of the book with a sharp knife and take care that you only cut the pages
Step 2: Make an Indentation (groove) in the Side of the Book
Make some kind of an indentation on the inside (see pictures) so that the bag can bent in the middle and open properly
Remove some cardboard with a knife and sand the groove afterwards
Glue double adhesive tape on the back and make sure to cover all the groves
You have to make a groove so that you can open the bag. Without groove (indentation) you can't bent the board in the middle and the bag can't open.
Step 3: Coat the Inside of the Bag With Fabric
Put your book cover up side down and draw the outline on the fabric
Cut your fabric 1 cm smaller on both the long side and the short side
Cover the coves with double adhesive tape
Glue your fabric on the book cover. You can also use wood glue on the hard cover but not in the groove as wood glue will become too stiff and this part needs to stay flexible for opening the bag smoothly
And yes, if I would make a bag again I would choose a fabric without a pattern :-)
Step 4: Make the Inside Frame
Measure the size of the pages of your book.Mine were 3.3 cm high. I prepared the wooden parts for the inner frame slightly thicker (3.6cm) as I will lose 3mm from cutting the wood in two at later stage (see next step)
Cut all your parts and sand the ends
Step 5: Glue and Split Your Frame
Glue your four pieces into a frame
Let dry and mark the center
Split your frame in two with your band saw
Step 6: Paint and Attach Hinges
Mark and drill holes for hinges
Paint the frame one time, let dry, sand lightly and paint again. Make sure you leave one side of the frame blank for better glueing to the cover
Step 7: The Handle
Mark and drill holes for the handle. I found the handle on an old kitchen door in a container with trash.
Mount the handle
Step 8: Mount Your Frame in Your Book to Get Your Bag!
Mix glue I used epoxy and apply it on your frame
Put your frame in the book and let it dry
Put some heavy books on top of to give it some presure
Step 9: Do You Want a Shoulder Strap?
Drill holes for hooks to mount the shoulder strap.I have some shoulders straps which I took from old bags
I painted my hooks the same colour as the frame
Don't worry if you don't have a shoulder strap, the bag looks wonderfull without too
Step 10: The Clasp
Measure
Cut the leather at the right length. You can use a leather belt or cut the bracelet from another piece of leather
Make a hole. I used a hollow punch tool. You can also drill your holes with a drill or use or a leather hole punch. The size dependents on your Press fasteners
Fasten your Press fasteners on both sides
Pre-drill a hole on the end of both leather strips to ease screwing
Apply double adhesive tape on the ends of the leather pieces (optional)
Step 11: Mount Your Clasp
Mark and punch holes with a piercer
Drill holes on both sides with a pillar drill
Take away the backside of the double adhesive tape
Tape your leather on the right place and fix the leather with screws
Step 12: Enjoy Your New Bag!
I am so happy with my new bag. Good luck with the construction, I hope you will get equally happy.
This instructables is submitted to the book contest
Bye bye and have a nice day/A'maries
