Introduction: Changing Cutting Wheel
Hi my name is Griffin
Radke. I like to help people learn the proper way to change cutting wheels on grinders and other power tools, in a fast and easy way. Some people have the fear of cutting a finger or hitting their knuckles while trying to do this. I help them do this in a safe and effective way. I’m going to show you all the steps you need to get this done so quickly your boss will be proud. I’m going to show you a killer way to get back to the job as quick as possible. You probably already know this but, changing a cutting wheel is a key part of working on the job.
Step 1:
Step 1: Set grinder on a flat sturdy surface.
Step 2:
Step 2: Take small tool specific wrench and lock it
onto shaft under cutting disc.
Step 3:
Step 3: Take 5/32 allen wrench and place in screw
head.
Step 4:
Step 4: Turn the allen wrench counter-clock wise until
screw is removed.
Step 5:
Step 5: Take spacer off the cutting disc and place to
the side along with screw.
Step 6:
Step 6: Take old cutting disc and toss in the trash.
Step 7:
Step 7: Put new cutting disc on tool and center as best
as possible.
Step 8:
Step 8: Put the spacer on the cutting disc with the
flat side up.
Step 9:
Step 9: Put screw back in and tighten, clockwise.
Step 10:
Step 10: Remove wrench from behind the disc and check
tightness. https://youtu.be/0PJB3ySrqaE
