Introduction: Chap Stick Safe
The chap Stick Safe is a cool little safe to make. It is a smaller container so it will only hold small items. I mainly use it for storing cash. You could put other stuff in it as well. It's nice for storing in a purse or draw to look inconspicous. This was a cheap project to make I had a chap stick laying around I used to make mine.
Step 1: Tools and Supplies
chap stick container
knife
paper towel and water to clean off chap stick
Step 2: Making
Making the Chap Stick safe is pretty easy and inexpensive. I used a pocket knife to make mine. Start at the bottom turning knob and start turning so the chap stick part is exposed. I reccommend using a stick that is towards the end so you don't waste chap stick. Turn the knob until the chap stick wont stick out of the top and farther. Then take a knife and cut what ever access lip bum stick out. Cut all chap stick that is on plastic thing that pushes up the chap stick. Can use a cutter also to cut this out. Water and paper towel helps clean up the inside of the container.
