Introduction: Charger HACK - Make Smartphone Chargers the Best!
HERE IS A SIMPLE CHARGER HACK, WHICH WILL MAKE OUR CHARGERS THE BEST!
All of us use chargers to charge our mobile phones, tablets, smartphones, etc. And most of the chargers that are available these days have two main problems:
  1. Two Pin Charger: Charger doesn't fix firmly into the plug point, it will be shaky, loose contacts, and the charger might fall down and get damaged too.
  2. Charger Cable length is small: We people use phones even when on charging and we might have wished if the charger cable could be a little more longer.
Step 1: Components and Tools Required.
  1. Electric wires with good quality insulation.
  2. 3 pin plug top
  3. Female connector
  4. Screw driver
  5. Wire stripper
  6. Insulation tape
  7. Charger
Step 2: Strip the Ends of the Electric Wire Using Wire Stripper.
Step 3: Connect Electric Wires to the 3 Pin Plug Top.
Step 4: Similarly Connect the Other End of the Wires to the Female Connector.
Step 5: We Will Get This Product at the End of Step 4 and Connect the Charger to the End of Female Connector.
Step 6: Tape Insulation Tape Around the Junction Between Charger and Female Connector to Keep the Connection Intact
Now we have a better charger. We don't need a long USB cable anymore, and our chargers will have a longer life.
Step 7: Now, Enjoy the New Charger ;)
The 3 pin plug top will stay firmer in the plug point, so no charging interruptions due to loose charger. By varying the length of the electric wire, we can make a charger of any length.
Step 8: Here Is the Video About This HACK.
