Introduction: Cheap Universal Fishing Line Winder
Build an inexpensive device (about $8.00) for filling fishing reels with line. Easy to use, tangle-free, solo-operable, far cheaper, and just as effective as commercial models, which sell for $30 to $120. It will work with all reels and spool configurations. Can be mounted horizontally on a table or workbench or vertically on a door or bookshelf.
Step 1: Tools and Materials
MATERIALS:
(1) 5-1/2" x 8" x 3/4" plywood scrap
(1) 1-3/8" x 3-1/2" x 7/8" hardwood scrap
(2) 1-3/4" wood screws
(1) 1/4-20 x 8" machine bolt
(2) 1/4" I.D. shaft collars
(2) thumbscrews to fit shaft collar set screw thread
(2) 1/4" I.D. x 5/8" O.D. x 1/2" thick nylon spacers
(2) 3/4" O.D. hard plastic conical faucet washers
(1) 21/64" x 1-1/8" x .035" compression spring
(1) 1/4" flat washer
(1) 5/16" flat washer
(1) 5/16-18 wingnut
(1) 2" x 3" x 5/16" square u-bolt
(1) 1/4" I.D. x 1-1/2" long rubber tubing
(4) self-adhesive non-skid spots
TOOLS:
Wood saw
Hacksaw
Flat file
Drill motor
13/64" bit or 3/16" bit
1/4" bit
5/16" bit
Appropriate countersinking bit for your wood screws
220 grit sandpaper
7/16" box end wrench
Wood glue
Measuring device
Screwdriver for wood screws
Square
(1) 5/16-18 wingnut
TOOLS:
Wood saw
Hacksaw
Flat file
Drill motor
1/4" bit
5/16" bit
220 grit sandpaper
Wood glue
Measuring device
Square
Step 2: Assemble
Photo One:
1- Cut out wooden parts. Sand smooth.
2- Drill a 13/64" hole 1/2" from the top of the piece of hardwood, centered on the 7/8" side
3- Use the 7/16" wrench to thread the machine bolt into the hole
4- Use the hacksaw to remove the bolt head and dress the cut with the file
5- Drill a 5/16" hole in the center of the 8" side of the base, 3/4" in from the edge
Photo Two:
6- Attach the upright to the base using the wood glue and the two wood screws in countersunk holes. The side of the upright should be 1-1/2" from the edge of the base.
7- Attach the 4 non-skid spots to the base. Put two at the corners of the 8" edge nearest the upright. Put the other two 1-1/8" from the other corners, along the 5-1/2" edge.
Photo Three:
8- Use the hacksaw to cut the U-bolt, making an L-bolt
9- Slide the rubber tubing over the short leg of the L-bolt
Photo Four:
10- Remove the existing set screws from the shaft collars, and replace with the thumbscrews. The thumbscrews may need to be cut off, leaving about 1/2" of the threaded portion.
Photo Five:
11- Use the 1/4" bit to enlarge the holes in the centers of the conical washers
12- Assemble the parts as shown, paying special attention to the orientation of the conical washers.
Photo Two:
Photo Three:
Photo Four:
Photo Five:
Step 3: Usage
NOTE: The rod, reel, and winder are shown close together for photographic convenience only. In practice, the line is passed through all rod guides and the tip of the rod is positioned a few feet from the spool.
Photo One:
Baitcaster, Fly, Center Pin and Alvey-type reels (axle of reel parallel to winder shaft):
1- Clamp line winder to a convenient vertical or horizontal surface using the L-bolt.
2- Remove outer shaft collar, spring, flat washer, nylon spacer, and conical washer.
3- Install line spool with the line unwinding off of the top of the spool, towards the reel.
4- Replace the conical washer, nylon spacer, washer, spring, and collar.
5- Position the spool in the center of the shaft and tighten the inner thumbscrew.
6- Make sure that conical washers are centered in the spool.
7- Achieve the desired rotating resistance on the spool by compressing the spring, then tightening the thumbscrew on the outer shaft collar.
8- Attach line to reel and reel away.
Note: When filling fly reels, center pin, and Alvey-type reels, the spool of line should be mounted on the shaft with the line coming off of the bottom of the spool, rather than the top.
Photo Two:
Open-face Spinning and Spincast Reels (axes of reel and winder in-line):
1- Clamp line winder to a convenient horizontal surface using the L-bolt.
3- Loosen set screw on inner shaft collar.
4- Place spool on shaft.
5- Replace conical washer, spacer, washer, and outer shaft collar. Spring not used.
6- Secure outer collar on the very end of the shaft.
7- Center the spool on the outer conical washer, slide inner assembly snug to the spool and tighten to prevent the spool from turning.
8- Attach line to the reel and reel away.
NOTES: The rod, reel, and winder are shown close together for photographic convenience only. In practice, the line is passed through the rod guides and the tip of the rod is held a few feet from the spool.
When filling spinning and spincasting reels, it is VERY important to pay attention to the line coming off of the spool. If this line begins developing twists or kinks, stop reeling and reverse the spool of line on the shaft. The line must spool off its spool in the same direction as it is wound on the reel. Often, but not always, the label on the spool of line should be facing the reel.
Good Fishing!
Photo One:
Photo Two:
Good Fishing!
