Introduction: Cheap Homebuilt Simple Solar Heater. in a UnderBed Case (in Progreess)
The other day I picked up 2 pack of 17.75"x6"x30" black with clear top zipper cases for storing stuff under beds. I only had a use for one, so I was interested in making the other one a small Solar Heater for my workshop.
Ive seen these things done before at the local solar fair, and i i figured it cant be too hard to make a small one
Step 1: Materials,
-One, 17.75"x6"x30" black cloth under bed storage container(bigger if you can find it,) But it needs a clear top
-One 80mm 12V computer fan and grill and mounting screws (these can be taken from computer cases or power supplies)
-Two, 9 volt batteries (I hope to replace these with a 12V solar panel soon)
-Two 9volt battery clips (probably moot if replaced with solar, but I may keep them for use in partial sun)
-Some cardboard, or black foam board
-Some black Duct Tape
-One length of dryer hose (probably best if its less than 10 feet mine is about feet long
Step 2:
Unpack the underbed storage bags,
I decided to make mine length wise, so i decided on what would be a top and a bottom, (both ends have handle loops so either end is just fine. just pick one.
I then took my foam board (black in this case, but cardboard painted black would work as well, probably better) I 2 rectangles about 6"x17.5" and duct taped them inside the top and bottom of the bag. I plan to get more foam board and make some sides and internal baffles but so far it works ok as it is.
Step 3:
Trace the inner circle of the fan (i did it with a pen through the fan) and then using a sharp razor cut through both the bag and the foam-board you don't have to be extremely exact, but being close helps cut down on stray noise and or air leaks.
I then punctured the corner holes and using the same screws and my trusty screwdriver that held the fan into a power supply mounted up the fan blowing upwards through the bottom of the bag.
PC computer fans all most always blow towards the label but there is usually a little direction of rotation and direction of airflow arrow on the outer plastic of the fan somewhere.
At this point i tested it, by hooking up the batteries and battery clips in series. (red fan wire goes to one battery clip red wire, the black wire of that clip connects to the red wire of the 2nd battery clip, and the remaining black wire goes back to the fan via the fans's black wire the fan was plenty to plump up the bag like one of those wacky inflatable Christmas lawn decorations.
Step 4:
Up at the "top" on the side i made a slit in the fabric and fed in my dryer hose, then duct taped it in place.
This is where the sun heated air is going to come out as a slightly flowing warm breeze
Zipped up the bag, and then added a fan grill, (probably not needed, the fan blades are kinda sharp and can whack you, but I mostly put the fan grill there to protect the fan, and to keep critters out.
I tested it the duct, the bag no longer plumps up totally full, because it can relieve some air pressure down the duct, but it does keep from collapsing.
Step 5: Conclusison and Improvements.
I have only had a chance to test it for about 10 minutes in the sun since i built it last night, but the air was pretty warm. (I hope to do measurements over the weekend, and see if putting some maze like baffles in the box can slow down the air and make it work any better.
In addition to baffles, Im thinking ov building a more rigid sides, and perhaps line the bottom of the "bag" with matte black card board, to keep it from collapsing/flopping. and perehaps to keep it from loosing any heat out the back side.
I want to experiment with making this solar, so the fan only blows when the panel is in the sun. jsut replace the 2 9v batteries with a 12v or 3 5v solar panels.
I'm also interested in building a reversed thermostat, so it will turn off the fan if the temp in the box is below a threshold. (will outline this one as I figure it out)
I plan to test this one to bring a little winter warm into my workshop, but i may build more and bigger ones for my house and other places.
Craftsman Workshop of the Future Contest
4 Comments
14 years ago on Introduction
Think you need to add more details and better Pictures on step by step constructions.Im very interested in this. PKM: It doesn't matter how cold it gets if you have SUN it will be warm Ice will melt under 30F as long as its sunny.
Reply 14 years ago on Introduction
I plan to post additional photos when i get a chance to drag it out for a test this weekend. I think i covered the instructions pretty well, let me know what parts are unclear to you and i will add on! Its still pretty alpha, i hope after this weekend it will be in a more fully usable state. and i will have some info on how it worked and tweaks.
Not every Pic is bad .Its the parts about the cardboard inside the bag where to put he hoses .The Fans.Where to put the bag and Hoses. Just needs to be more clear with slightly more details .Over all Its nice and got my attention.
This looks like a good repurposing of a cheap object, I might even have one of those bags under my bed! Baffles would probably help (black painted card should be all you need), and I love the idea of a solar fan to only use the heater when there's enough sun to make it worthwhile. I doubt it would help much here though, perpetually cloudy days and sub-freezing mornings and evenings mean it would probably lose more heat than it gained. It's a nice idea, though.
