Introduction: Cheap Plywood Kayak Project
They needed a fast, inexpensive, roomy kayak for travel. The choice fell on a plywood kayak using "sew-and-glue" technology.
Step 1: Planning
Drawings of the "Chesapeake 17" and "Shearwater-17" project were found on the Internet. Approximately the same as in the photo. A little bit to adjust for yourself. I narrowed it down a little and raised the "deck", added a couple of bends. (Unfortunately the drawing was lost during construction). You can start building.
Step 2: Preparation Tools
Find a spot large enough for a kayak. We collect the slipway (large table)
The tool I am using:
- jigsaw
- Sander
- knife
-scissors
- clamps
- brushes
- syringes for resin
- pliers
- respirator
- rulers
- miscellaneous as needed
Step 3: Preparation Materials
We buy 4 sheets of 4mm plywood. Epoxy resin 3 kg, 2 slats
Step 4: Preparation
We mark the plywood (sheet dimensions 1525 * 1525mm) according to the width of the parts in the drawing and saw it. We "sharpen" the cut pieces and peel them with epoxy resin.
Step 5: Transferring a Drawing
Transfer drawings to sewn plywood
Step 6: Cut
Sawing along the drawn contours.Sawing along the outlined contours.To make both sides even, you need to fix two identical parts with clamps.
Step 7: Fixing the "deck"
To attach the top of the kayak, glue the prepared slats to the cut-out sides
Step 8: We Sew
We sew the resulting parts with wire and see how beautiful it turns out
Step 9:
Installation of bulkheads and alignment / gluing of slats.In the project from the Internet there was a drawing of the bulkheads, but since I changed the kayak for myself, they no longer fit. I had to take cardboard and cut it in place. Transferring the cardboard stencil to the plywood
Step 10: Filling Joints
Аill the joints with a mixture of resin and wood flour
Step 11: Stabilization
To stabilize the bottom, I put 1 layer
Fiberglass Evenly spread epoxy with soft spatula
And also the future cockpit (the place where the person sits) I cover with fiberglass with epoxy resin
Step 12: Deck
It's deck time . I fit the plywood to size and fasten it with self-tapping screws
Step 13: Fiberglassing Deck
Cover the deck with fiberglass and sprinkle it with epoxy, spreading it evenly.If the resin is too thick, you can warm it up with a construction hairdryer
Step 14: Details
Cut out hatches and cockpit, give shape to hatches. I made a model of hatches from paper.transferred to plywood
Step 15: Fiberglass in All
We cover the deck and bottom of the kayak with two more layers of epoxy resin fiberglass.
Step 16: Priming and Painting
After the epoxy has hardened, proceed to painting. First applied the primer, and then the paint
Step 17: Sundry
I add the fastening of the hatches, and the trunk from the rope
Step 18: Testing
Testing
Step 19: Outriggers
If your kayak is not stable, do outriggers
Step 20: Outrigger Construction
From the remnants of plywood or from a new sheet, a crossbar and 2 mini-kayaks are glued together, everything is fastened together. Cover with epoxy fiberglass and paint (like a kayak)
