Introduction: Cheap Selfie Light
How to make cheap Selfie light from 20 W Tubelight
1. Soldering Iron
2. Fevi-quick
3. Plastic
4. Hacksaw blade
5. Wires for joining
6. Double-side Stickers
7.Plier
Step 1: Take 20W Tubelight With Measuring Tape
First Take 20W Tubelight and Measuring Tape
Step 2: Measure the Length in Cms
Measure Tubelight in Cms. Here my tubelight length is 118 cms
Now Divide into 4 pieces ,Mark in Tubelight with Marker
=118/4
= 29.5 cms
Step 3: Remove Side Protective Cover
Use screw driver and gentle push the nob
the Side cover fall off.
Use same technique in opposite side too.
Step 4: Desoldering the LED Wire
Caution: Remove the Plug and wait for 10min until all current in capacitor looses.
Now Desoldering + terminal and - terminal of LED strip.
Step 5: Remove Top Cover and Inner Circuit
Slide of Top cover and separate from base.
then pull LED + wire and get the circuit.
keep it separate for final sodering
Step 6: Cut Down
1. Cut down both bottom holder and top protective Plastic into 29.5 cms
2. Scrub the LED strip and make sure Copper easily visible from all 4 pieces.
3. use wires and soldering the wires similar to original layout.
4. soldering both ends
5. Add LED driver circuit solder + LED terminal and - Led terminal similar like original Wiring
Step 7: Final Arrangement
1. After careful soldering of all 4 pieces.
2. arrange like rectangle.
3. use Fevi-quick and paste backside some plastic for support.
4. use 45 degree L angle plastic for support all 4 corners inside of Selfie light.
