Introduction: Cheap Surround Sound System
Have you ever looked at those extremely expensive surround sound systems, but didn't want to spend $200 or even $500 on something you could make for around $20. well here is you answer a really cheap way to make a surround sound system
Step 1:
Materials:
1. Speakers (because i am not an expert on speakers you are on your own for this part. i use some speakers from my sisters old stereo it was an RS2046.)
2. some kind of tape to tape the speakers together. ( i used electrical tape but you can also use duct tape but i do not recommend using clear tape cause it isn't very strong.)
3. Soldering Iron (extremely recommended if you want your surround sound system to last.)
4. Solder
5. Wire ( if the wire already connected to your speaker dose not reach you stereo.)
4. Solder
Step 2: Tape Your Speakers Together
ok so now that you have your materials you want to tape the speakers together. this is kind of hard because the speakers will try and oppose each other because they have magnets in the middle. after you have taped the speakers together then you want to tape the wires together, but only up to 4 or 5 inches from the speakers. the tape will act as kind of a guide to how low you want it to hang from your ceiling. after you are done with that then you want to tye a knot into the wire so you can hang it later. now if your wire dose not reach the stereo system then you want to solder more wire onto it.
Step 3: Connecting to Your Stereo
OK as you can see i added a lot of extra wire. after you have added any extra wire then you can connect it to your stereo system where you would hook up your external speakers. i also added a video but i dont know if it will work so if you have any questions or comments please comment and i will try and get to you ASAP. THANK YOU!
NOTE: TO OPEN THE VIDEO CLICK ON IT AND DOWNLOAD IT THEN OPEN IT WITH QUICK TIME OR ANY OTHER APP THAT WILL OPEN A VIDEO.
