Introduction: UPDATED !!!! Cheap and Easy WIFI Antenna Signal Booster That Is Better and Quicker Than the Paper Ones !!!
A new swing on an old idea for improving your WIFI signal!
Step 1:
I call this WIFI booster ad on the POPtenna because you make it from a plastic pop bottle.
First get a clean plastic 2 liter pop bottle.
Step 2:
Strip off the label if there is one and wipe down with a cleaner that does no leave a residue.
Step 3:
Using a large sharpy pen, mark a ring around the bottom and a window that takes up just half of the diameter of the bottle as shown.
Step 4:
Cut out the window first so the bottle will have stiffness to help with the cutting and then cut off the bottom of the bottle.
Step 5:
After doing all the cutting, you must clean out the bottle's inside with windex or an equivelent cleaner.
The as you see by the photo.... get out your tin foil and glue stick and get ready for the next step of lining the inside face of the bottle with tin foil and making it as smooth as possible.
Step 6:
As you can see by the photo, it is only the back of the inside that gets the tinfoil. This is to make a vertical dish to focus the signal beam back into your vertical omnidirectional antenna.
Step 7:
Now this may be one of the most important parts of the antenna dish. I hope you save the cap because we are going to make an adjuster ring from it. Mark an X on the cap and make a clean cut though both lines. When finished, replace it onto the bottle neck.
( UPDATE)
Upon a few peoples suggestions..... It has been noted that if you make the cut at the edge and not the center the signal will be much higher. I totally re-did the cap as they suggested and my signal went up from 76% to 90. OK GUYS POINT TAKEN !! So having said that....
Adjust accordingly to follow RIMAR2000's suggestion to move it at least an inch or so closer to the reflector. You were right and I was wrong.
Also if you get a chance, follow the link that RIMAR2000 has on his comment and you will see where he got his information, granted, you will have to translate it, but, if you look at the diagrams... It all makes perfect sense !
Thanks RIMAR2000!
Step 8:
Now you are ready to place the reflector onto your antenna. Slide the antenna into the center of the X you made in the cap and then force the bottle down over the antenna until the top of the antenna is level with the top of the reflector. Now you place your antenna in a high place and experiment with it by turning it until you see a boost in the signal strength on your computer. This reflector is good because it covers the entire length of the vertical antenna and is very adjustable both right to left and in and out too.
Step 9:
As you can see I have a very strong signal pick up! Before I had a 30 percent signal and now look at it!
Up to 76% and running great!
Funny thing is to about this is the router is over 100 yards away in our office at the place I live!
They offer free WIFI in the clubhouse and office, but, I can use it from a long ways away now!
Have fun and I hope this helps with any signal issues you may encounter in your WIFI network.
P.S. the antenna that I was using before was a 7dbi antenna and now it is on steroids!
Party Like It's 1929!
87 Comments
Question 2 months ago
Which type of material can we use for the antenna and can it boost the mobile internet signal ?
12 years ago on Introduction
Very cool instructable. But the focus of the reflector is not in their curvature center as you suggest, but approximately halfway the distance. That is to say that approaching the antenna to the reflector approximately one inch, that should enlarge the profit.
Reply 7 months ago
How long can the antenna cable be(maximum length) before reaching the reflective surface? Can the surface be copper or other metal? Or I better test them to see the differences?
Reply 7 months ago
Ask to the author, AndyBMX30.
I think any metal works, and that the length of the cable doesn't matter.
Reply 4 years ago
sir it is impossible to do what your saying if the distance is made one inch the signal goes to 23.35% only
Reply 4 years ago
Please read this paper:
https://en.wikipedia.org/wiki/Curved_mirror
Reply 4 years ago
also: https://en.wikipedia.org/wiki/Parabolic_antenna#D...
and: https://en.wikipedia.org/wiki/Parabolic_reflector...
Reply 12 years ago on Introduction
RIMAR2000.... Thanks and take a look at the updated instructions noting your suggestions. the signal went from 76 to 90 upon the information you sent. It took a long time to translate that page, but, it was worth it in the long run. Thanks! Consider yourself a co-designer of this project.
What if you took the cut away piece, put foil on that and mounted it on three or four distances?
Bueno, no es para tanto... (well, isn't for so much... ) Thanks for your info.
9 months ago
Can I get WiFi from 6-8km far
1 year ago
My Wi-Fi router doesn't have an external antenna how can I boost it
6 years ago on Introduction
What if I don't like Diet Coke!? =)
Reply 4 years ago
The residue from the artificial sweetener they use is what gives it the boost. You can use a different soda but make sure it uses the same sweetener you should be ok.
and make sure you do not wash the bottle as that will reduce the effectiveness.
Reply 2 years ago
Even better if you rub Splenda all over the inside of the bottle and along the cabling. But only use natural sugar within the connector to your network interface card or you might pick up cell phone calls.
3 years ago
My router has 3 antennae, would it be beneficial to use a signal booster for each of them with a large one for the center and 2 smaller ones for the others or would that create interference between them?
4 years ago
what about build in wifi devices :(
5 years ago on Step 8
Its Awesomeeeeeeee
5 years ago
Thanks Done
5 years ago on Introduction
You never made mention of the Long white item, that goes through the bottle cap
