Cheap Flying Lego Quadcopter
Intro: Cheap Flying Lego Quadcopter
Ever needed an excuse to start building Lego again? Now is the time! Turns out Lego bricks can be used to build a perfect symmetrical frame for your quadcopter! And... it's super cheap.
I used Lego Technic because it has holes in the bricks. You can mount the motor's with tie wraps through the holes and it's an ideal weight reduction. For the motor's and flight controller I used parts from the famous Hubsan X4.
Interested...? Then dust of those Lego bricks and start building!
STEP 1: Tools and Materials
You'll need the following tools/materials:
- Lego (of course)
- Soldering iron
- Elastic band
- Soldering tin for electric components (optional)
- Doublesided tape (optional)
I ordered my Hubsan X4 parts from Banggood.com. http://www.banggood.com/buy/Hubsan-x4.html They have the parts even cheaper then ebay. This is what you need:
- Hubsan flight controler 107l or 107c (107l if your planning on adding fancy led lights, 107c if your planning on adding a camera)
- 4 7mm hollow cup motors
- 4 blades (and maybe some spare)
- 3.7v battery + charger
- Hubsan remote (if you dont have one)
If you don't have a remote yet, then it's probably cheaper to buy a rtf hubsan x4. You can take it apart and as a bonus you get the original hubsan x4 frame!
STEP 2: Soldering the Flight Controler
This requires a little soldering but nothing really hard. If you look at the flight controller, the place where you need to solder the motor's is already labeled.
And as you've probably seen there are clockwise and counterclockwise motor's. It's important to place the same motor's opposite of each otter. So clockwise motor opposite of the other clockwise motor and same for counterclockwise.
The flight controller already has some soldering tin on it, but it's not much. So you can add some extra if you want.
STEP 3: Building Your Lego Frame
I will let the pictures do the talking. You don't have to build exactly the same frame I build. With a little imagination you can build some awesome frames! Just don't make the frame to heavy or it will be very hard to fly (if it even has lift off). Please share you awesome frames for inspiration!
STEP 4: Mounting the Motor's and Flight Controller
What I mentioned earlier is that Lego Technic is perfect for mounting the props. It has holes in the bricks and all you need to do is mount the motor's with tie wraps trough the holes. I also used double sided tape to keep the motor's in place. Fixate the flight controller on top, battery under the frame and your good to go!
Let me know if you have questions, I'll be happy to answer them. Good luck building your own Legocopter!
121 Comments
abiddemi 6 years ago
I dont know where any thing is. pls help me
Weseley 6 years ago
If you need all the parts. Maybe it's best to buy a complete set. It has everything you need. You can take it apart and use the parts. Let me know if you need more help.
https://www.banggood.com/Hubsan-X4-H107C-2_4G-4CH-RC-Quadcopter-With-Camera-Mode-2-RTF-p-75824.html?rmmds=buy&cur_warehouse=CN
221910306044 3 years ago
drone138 4 years ago
I looked at Bangood but I can't find anything I need. Pls help.
arvlag862 6 years ago
Hello again!
We put together the drone and connected the battery, leds starting to flash and it all seems to work great. One problem though, we can't get the controller connected to the Hubsan Control. Any ideas how to do it?
Weseley 6 years ago
Hello there, sorry for the late respone... But if the leds are flashing when you connect the battery, that means it's waiting for a connection with the transmitter. Just turn on your transmitter when the leds are flashing and they should pair. After that, you should be able to control your drone.
Hi again!
It turned out that you need to push one of the rear end buttons on the transmitter when you started the transmitter in order to connect the the transmitter with the receiver. Now it all works just fine!
Weseley 6 years ago
Cant remember doing this in order to connect. But great to hear it works, have fun!
leletsr 6 years ago
hello,
I've tried building the drone with the following pieces but it is not working. I don't know if it is a compatibility problem or one of the components is not working. I don't know how can I check if they run indepeniently. Do you know where I can find the manual of the components (I haven't found nothing)?
-Hubsan X4 H502E H501C H907A RC Quadcopter Spare Parts Transimittervs
-2 x 7mm Hollow Cup Motor For Hubsan H107L Upgraded Version
-Hubsan X4 H107C RC Quadcopter Spare Parts Receiver H107C-a43
Thanks for your help and great job!
Weseley 6 years ago
Do you see leds flashing when you connect the battery? If that's the case, you should turn on your transmitter and it should pair automatically.
williamgustafso 6 years ago
Hi! I am going to build this drone in Lego as a project in school. I do not have a lot of money so just I want to make sure I buy the right drone. Is this the recommended one?
https://www.banggood.com/New-Version-Upgraded-Hubs...
Weseley 6 years ago
This is a newer version, but you can definitely use this one! Just take it apart with care ;-), good luck!
Hey Weseley, can you please check my parts? Do they really work together or do I need to change something? I was a bit confused due to your broken links.
https://gyazo.com/31acf3bac25dccfa22ec7d6e1186659f (link with all the parts)
Weseley 6 years ago
Yes, you got the right parts! Thanks for mentioning the broken link, I'll fix it this weekend. Good luck!
Thank you so much for the answer!
AntonioJ15 6 years ago
Hello, is it possible to control the drone by the smarthphone with arduino+bluetooth?
GavinK12 7 years ago
Hey Weseley! Is there anywhere I can buy a good controller individually while still fitting a low budget profile?
Weseley 7 years ago
Hello Gavink, the controller is about the most expensive part for the project. But you can make your own controller with an Arduino and RF transmitter. It's a lot of work but the price will be under $10.
