Cheap Simple Tripod for Your Pocket
Intro: Cheap Simple Tripod for Your Pocket
The "tripod" made from a string and a 1/4 inch bolt is a well functioning and cheap classic that every photographer should have in the photo bag. But I have always had a problem with the string entangling in their bag, so here is the solution that makes sure you always have a tripod handy and don't look like a fool unraveling strings...
STEP 1: Material and Tools
You need the following material:
- A rubber band
- 3-3.5 m (12ft) of string – braided nylon works well
- 40x80 mm 9 mm plywood
- A 1/4 inch 37 mm bolt (1.5 inch)
You need the following tools:
- A 7 mm trill
- A jigsaw
- Sanding paper
- A hammer
- A lighter
- A scissor
STEP 2: Template for the Coiler
Print the template and cut it out.
Test if the bolt fits the camera's tripod mount and measure how
deep it goes. Use a marker to draw a mark on the bolt, where it sticks out of the mount. Lay the bolt with the mark on top of the template to determine if you need to adjust the size of the coiler. The coiler needs to start at the mark. The bolthas to stick out a couple of mm so it will screw into the tripod mount.
When you have determined the exact size, draw the template on the plywood.
STEP 3: Making the Coiler
Cut out the coiler with a jigsaw.
Drill a 7 mm hole across the coiler according to the template
Sand the coiler's edges
Saw two narrow slits for the sting in the left and right side of the hole
STEP 4: Fixing the String to the Coiler
Pull the two ends of the string through the hole and fix them in the two slits
Push the bolt through the hole to fix the string
Cut the strings' ends so that there are only a couple of mm sticking out
Melt the ends of the strings with the lighter so they aline with the coiler and seal the hole
STEP 5: Done
Add the rubber band so you can fix the string when you roll it up on the coiler
You are done!
Time to test the tripod! Every camera has a different mount, so the bolt may or may not fit the exact depth of your bolt, but don't worry if it doesn't fit tight, it's not important for the stability of your tripod...
The image was shot at 1/2 a second exposure time at ISO 200 @ 28mm with the tripod – check out the 100% cut out from the center – pretty impressive! (Stability improves a lot if you place the camera against your forehead by using the eye viewer. Also using the self timer will prevent camera shake from pressing the exposure button...)
Use the tripod by standing on the string and pulling the camera upwards to make a tight triangle. This will stabilize the camera and make up for around 3 or 4 f-stops – enjoy!
27 Comments
Fr_3d 5 years ago
Thanks for this nice design. I liked it so much that I converted it into an STL file for everyone to print on a 3D printer:
https://www.thingiverse.com/thing:3250479
Best regards,
Fr_3d
inspiredwood 5 years ago
tholopotami 10 years ago
Old and tested trick. You implemented it very well. I have used the one foot version!
dsantil71 9 years ago
Luc Volders 9 years ago
What a great Idea !!
Made one myself after a long search for a tripod screw as these are hard to get here in Holland.
I did it slightly different though: I designed and printed a base for the cam to be mounted on. Although the base is specific for my Canon SX110 cam you can download the files at my website: http://lucstechpage.weebly.com/
Thanks for sharing.
Luc
inspiredwood 9 years ago
Ha, ha, NICE! Thanks for sharing :-) Awesome!!!
craftclarity 9 years ago
Thanks for posting this! A trick I'd not seen yet. Thanks for sharing it!
DarkHatter 10 years ago
That's a bi-pod.
dummy1977 10 years ago
Either way, It makes it easier to search for by calling it a familiar term.
True dat!
keng 10 years ago
mabreu francescoli 10 years ago
thats not a tripod, but is another way to have a similar option, i used tripod with video camera, and the best of the tripod its hands free, good job!
legless 10 years ago
Just a minor thing. It's a 1/4" bolt not a nut. Calling it a but is just a bit confusing.
inspiredwood 10 years ago
paulofilhojotaerre 10 years ago
Legal!
hermanwahsletn 10 years ago
I have a string around my neck:
https://www.youtube.com/watch?v=KiA3OLJ0juk
rose_adamaj 10 years ago
So so perfect for me!!! I am disabled & have been looking for a way to steady my monocular & binoculars for birdwatching. I use a power chair & can only carry so many things, this will even fit in my cup holder. Thank you for posting this well done ible!!!
mickryobe 10 years ago
inspiredwood,
String pods have been around for generations but your is the first I have seen that utilizes both feet. I shall have to try it.
A word of caution: Always use your neck strap with is device as it and gravity are conspiring to bring it to ground.
Mickey
junkrigsailor 10 years ago
