Introduction: Cheat on Any Wii
This instructable is for all you cheaters out there (I only cheat when i beat the game and want online supremacy)
I AM NOT RFESPONSIBLE IF ANYTHING BAD HAPPENS TO YOUR WII
What you need
Wii that's able to run homebrew
SD Card
Ocarina
What you need
SD Card
Ocarina
Step 1: Get Codes
To get codes go here
Click on any game you want codes for
At the top of the page click download
save the .txt file to your desktop
Step 2: Converting/Editing Codes
Unzip the ocarina files
go into the "pc" folder in the unzipped file
run codemgr.exe
insert the SD Card
in code manager go into File => open TXT file
browse for the txt file you downloaded
open it
Check all the boxes for the cheats that you want
In alot of things you check there are groups of X's (ex. XXXXXX)
the X's are variables
the lines on he left in Italic should tell you what the variables should be or check in the "Code Comment" section below the actual code to see what the variables should be.
you should get the hang of it soon
When you are all done click export to .gct
--If You Get Errors--
Error: "Error at code:"
Fix: Check your Variables!
Error: "No codes selected"
Fix: Check the checkboxes (at least one has to be checked)
--If you get no errors--
select the drive letter that your SD Card is (check my computer to get it)
click Store (NOT STORE TO FILE)
run codemgr.exe
insert the SD Card
open it
Step 3: Running Codes
boot ocarina (boot.elf is in Unzipped Folder => hbc => ocarina)
insert the target game and press A on the Wiimote.
It should say:
"Found Code List!"
"Applying Code List!"
at the end
the screen will flash a wierd green color for a milli second and then the game will boot with cheats applied. Booting from the disc channel will not apply cheats for when your not in the mood to cheat you way to the top.
It should say:
"Found Code List!"
at the end
