Introduction: Check Your Hub Motor Wheel - Electric Bike Kit
Order 1 set of electric bike kit from manufacturer-leaf motor and convert your bike to e-bike is a fun. But sometimes when we receive packages and don't know how to hanle it. Follow us:
Before install electric bike kit, we should test it first.
Step 1: Deliver your package
Spent some days on Internet, at last found leaf motor 's electric bike kit is the best. Ordered it and paid by paypal. Waiting for... About 3 days later, post officer knocked my door (EMS) and sign in it.
Check packing box first ,if it's okay. Pls disconnect electric bike kit box.
Step 2: Check all goods in package
Take out 26" hub motor rear wheel, bldc motor controller, lcd, throttle, brake lever, three button switches, speed signal wire and some connectors from packing box. Check each goods and make sure everything doesn't have fault.
Step 3: hold on 26" hub motor wheel
Put the hub motor wheel on your frame fork and tight both screw nuts.
Step 4: install magnet detector
Step 5: connect wires
1.Plug male 6-pin hall wires from hub motor cable to female connector from bldc motor controller;
2.Connect heavy yellow, green, blue from hub motor cable to heavy yellow, green, blue from bldc motor controller, color to color;
3.Two grey wires: connect these two wires/half speed; disconnect them/full speed;
4.Throttle connector is 3-pin that is easy to identify. Red: +4.5V, black: GND, green: Signal
5.Brake lever connector is white 2-pin.When hub motor is working, press brake lever is to cut off power;
6.Signal wire is black three pin plug that should be connected to white three pin female connector.
7.The other three pin connector from bldc motor controller is used for PAS;
8.Connect four pin lcd plug.
Make sure each wire is connected correctly. Power on battery.(Heavy red wire: +, black wire: - )Be careful,36V controller must work at 36V battery, if supply 48V DC, it will break the bldc motor controller at once.
Power on battery and press ON/OFF button on LCD one time, the LCD will light. Twist your throttle,hub motor starts to run. No strange noise...Press brake lever, electric bike kit system stops, loose it,the hub motor runs.
Pls watch video .
https://www.youtube.com/watch?v=SrwYae6zOMA&feature=youtu.be
By test electric bike kit system, we found hub motor wheel, bldc motor controller, throttle.. everything is good. Next step is that we start to convert them on bike.
Hub motor, electric bike kit supplier: Leaf Motor Technology Co., Ltd
Website:http://www.leafmotor.com
Pls watch video .
