Introduction: Cheep and Easy 3 Minute Barbed Wire
What do you do if your sitting outside drinking your soda and you realize you need barbed wire? Easy you pop off that Pop tab and grab some wire
THIS IS DANGEROUS PLEASE DONT NOT PLAY WIRH
Step 1: What You Will Need
You will need:
Can tabs(one tab will make one barb)
Frame wire
Pliers with cutters
Frame wire
Pliers with cutters
Step 2: Cutting the Barbs
You want to take your cutters and cut the ends of the can tabs. You will want to cut them on the end that is attached to the can, and the side you pull on.
Step 3: Making the Barbs
You want to twist the center of the tabs
Step 4: Adding Barbs to Wire
Take the can tab barbs that you just made and wrap the wire around them.
Keep spaces between each barb.
You can add as many barbs as you want
Step 5: Extra Information
These are not very sharp but they will hurt when grabbed. You can sharpen them if you need you just need a metal file. Please realize these are dangerous please do not play around with these
The more can tabs you have the more barbs you will have
