Introduction: Cheese Cherry Blossom
Cherry Blossoms are pretty therefore why not with cheese.
You need a block of cheese and a butter knife with a small knife for details.
Step 1: Cut Your Cheese Into Shapes
First grab your piece of cheese and cut a long rectangle. For my block of cheese it was pretty thick therefore I cut that piece of rectangle into half horizontally. Then also cut a few pieces of square shape for the blossoms. If it is also too thick cut it into half horizontally.
Step 2: Shape the Branches
You can choose to have more branches but I picked two. With the two long rectangles and your butter knife shave some of the cheese off, so the branch would look flat. Then use your butter knife to press the branches to make it more flat then use your small knife to make some detail or branches.
Step 3: Make Some Blossom
Then use your square cheese and small knife to make the blossoms try using different kinds of flower shapes also if it fall apart like a blossom on my bottom branch don't stress you can make it as a petal that is falling or small decorations.
Step 4: Make Them Together
Finally put all the cheeses together with the branches on the bottom and blossom on the top. You can also put flowers around the branches or petals like I did too. Now admire your Cherry blossom cheese.
