Introduction: Cheese, Potato and Onion Jaffel
What's a Jaffel? It's a toasted sandwich which has the edges sealed in.
Apparently, the Jaffle Iron was designed, named and patented in Australia in June 1949 by Dr Ernest E. Smithers, : Its a bit like a 'Pressure Toaster'. You can also get jaffel irons to use on camp fires. These made of cast iron can provide a tasty snack while camping.
Talking of tasty snacks, this jaffel filling is one of the best (IMHO) and makes a change from bake beans and cheese.
Step 1: Potato Preparation
- Cut up some potatoes and cook by boiling. The ones I had were prewashed, so I didn't peel them.
- Once cooked, mash them up. I used a fork but you could also use a potato masher.
Step 2: How to Cut an Onion
Here' a easy way to cut an onion:
- Cut the onion in half
- Cut of one end off while leaving the other end on
- Peel the half
- Make cuts vertically, away from the end still attached
- Slice horizontial, I do this slighly downwards
- Slice crossways, this completes the dicing of the onion half
Step 3: Mix and Season
- Mix the onion in with the mash potato
- Mix in the cheese
- Use your own judgement for the quanties of each ingredient
- Add in some seasoning
Step 4: Cook
- Spay a bit of cooking oil on to the jaffel iron, or what you can do is butter one side on the bread and place this side against the iron's surface.
- Spoon in the Cheese, Potato and Onion mixture. I normally put in a little too much filling, just the way it goes.
- Place on top another slice of bread
- Close the jaffle iron together and cook to perfection.
Step 5: Eat
- Remove the jaffle from the iron and serve.
- Can also be enjoyed with a refreshing beverage.
