Introduction: Cherry Chili Dark Chocolate Bar
Hey everyone,
This is my first instructable, so hopefully it turns out well.
This instructable will teach you how to make a really good dark chocolate bar.
My roommate a while back bought some really expensive chocolate bars and one of them was a cherry chili dark chocolate bar, and I figured it wouldn't be too hard to make myself.
The ingredients needed are:
dark chocolate ( I had 4 Hersey special dark bars)
1 bag of ground chili pepper ( I bought Mi Costenita Chili Arbol Molido) A lady that I asked at Cash Wise said that it was "muy picante!"
1 bag of cherry flavored Craisins ( It was about half the price of dried cherries)
1 Zip-Loc bag
Mixing bowl or something to use as a form
Step 1: Melting the Chocolate
First turn stove on to medium or around that. I just didn't want to burn the chocolate.
Next: add chocolate pieces to sauce pan. ( I broke mine into pieces to make it easier to melt)
Step 2: Adding Cherries and Chili
The next step is to add the cherries and the Chili.
I added about 1/3 of the bag of cherries to make sure that I had cherry flavor in each bite.
Then I added 1 tablespoon of the chili powder to start off with. You can add as much or as little as you want, but I wouldn't add too much because then it would take over the flavor of the chocolate and cherries.
Cook the chocolate and remember to continually stir to prevent burning. Cook and stir until it is completely melted and thoroughly mixed.
Step 3: Put in Mold
The next step is to take the chocolate and place it in a form to harden.
I had a stainless steel mixing bowl that I put my chocolate in, so that it would be easy to remove once cooled.
Once in mold, it is optional to place it in the freezer to quickly set up the chocolate. I did this and it worked great because it made the chocolate very hard and easy to remove.
To remove chocolate, I placed the bowl upside down on a towel and then hit the bottom with a solid object and the chocolate just popped off the bowl and into the towel.
Step 4: Storage
Place chocolate in plastic bag to keep it fresh.
The last step is to enjoy!!! omm nom nom
7 Comments
12 years ago on Introduction
mmm tasty )))
14 years ago on Introduction
Yeah, as you've said below (author) if it starts to thicken while you are melting (and only metling, not 'cooking' - only ever use 'low'), it's burned. Chili-chocolate is the bomb. Thanks for the recipe!
oops i meant bain-marie, my double boiler is for rice, it probably would work though
yeah, I did kinda burn it. I have a double boiler but I couldn't find it, and I got impatient :S as far as spiciness, I put in about 2 tablespoons and its spicy. I'm going to do it again sometime and maybe only use 1 tablespoon. Even though it is spicy, it is really good! You just can't eat too much, too fast. Todd
It looks like you may have overcooked this a little, next time use a Bain-marie?
L
An easy way to melt the chocolate is to just wrap a Heating Pad around a metal bowl. There is enough heat to melt the chocolate, but no where near enough to burn it.
If you don't want big circular slab'o'chocolate, an ice cube tray makes good squares (but test it first to make sure it won't melt with the heat). How did your mix turn out for spiciness/cherry-ness? If it was way too spicy and you should only use a teaspoon of chili, that is the sort of thing we should know :) Good instructions and photos- maybe pull back a bit with the closeups if using a phone camera to reduce the blurriness, or use macro mode (flower symbol) for close focus, but otherwise good work.
