Introduction: Chessboard Wood DIY
Manufacture of a veneer chessboard with photo and explanation step by step, simple enough to implement. The manufacture requires some tools.
Equipment:
- Veneer saw
- plating
- a sheet of plywood or medium
- gummed paper
- wood glue
- clamps
You can find my other establishment on:
Step 1: Preparation
We must prepare a plate with a guide dimension on the right or left. And a loaf of width appropriate breaks.
Step 2: Cut Veneer
Veneer strips cut using the saw
Step 3: Assembly Bands
Assembling the strips using gummed paper 2 alternating colors veneer.
Step 4: 2em Cut Veneer
Make a clean cut and cut perpendicular strip the veneer again as the photos below.
Step 5: Assembly
Assemble the veneer with the gummed paper by making a shift.
Step 6: Contour
For what it wishes you can add an outline.
Step 7: Tackle the Chessboard
Also prepare the veneer for the underside of the Exchequer
Make a hinge system with masking tape, it will prevent the veneer sticks awry.
Paste all the wood glue and put masking tape so it does not move when tightening.
Place the board between 2 large plate with a sheet of newspaper between the veneer and the 2 plates and then put some green seal.
Step 8: Cleaning
Use a sponge with warm water and a spatula it should suffice.
Step 9: Collage Songs
Cut the square chessboard and paste the songs.
For it to be simpler spread the glue on the edges and wait for it to dry. Once dry plating position and pass an iron shot to iron on a cloth between 2 to prevent spotting.
Step 10: Finish
Sand and glaze the board. There it's finished.
Feel free to liker.
Thank
